MarkMc Posted March 19, 2019 Share Posted March 19, 2019 Am I missing something here? simple and easy in X10, no result in X11 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted March 19, 2019 Share Posted March 19, 2019 Ya think it might have something to do with the macro cap. thing? Link to comment Share on other sites More sharing options...
Kbird1 Posted March 19, 2019 Share Posted March 19, 2019 Sumpin ain't right.... %scale% still works and %view.name% works in a RT Box..... it seems most other macros work..... *** In this case there are no CAPS in the Macro P. Link to comment Share on other sites More sharing options...
MarkMc Posted March 19, 2019 Author Share Posted March 19, 2019 These are macros from the drop down list. Also just found that I'm not getting pages numbers on elevation callouts when text below line is set to automatic and adding int %layout.label% does nothing. Tested a layout box label and that macro does not work there nor does %layout.title% Yes I had tested view name and it works in a RT box Link to comment Share on other sites More sharing options...
Kbird1 Posted March 19, 2019 Share Posted March 19, 2019 On 3/19/2019 at 2:53 PM, MarkMc said: These are macros from the drop down list. Also just found that I'm not getting pages numbers on elevation callouts when text below line is set to automatic and adding int %layout.label% does nothing. Tested a layout box label and that macro does not work there nor does %layout.title% Yes I had tested view name and it works in a RT box Expand Yes see above , I edited.. all from the dropdown , tried typing in too.... PS thread title needs slight adjustment Link to comment Share on other sites More sharing options...
MarkMc Posted March 19, 2019 Author Share Posted March 19, 2019 On 3/19/2019 at 2:53 PM, MarkMc said: Also just found that I'm not getting pages numbers on elevation callouts when text below line is set to automatic Expand well sent both in, that one they could not reproduce. Sent it that plan and just to be sure opened it and now the view callouts are working. So it is some sort of sporadic issue. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 19, 2019 Share Posted March 19, 2019 On 3/19/2019 at 5:05 PM, MarkMc said: well sent both in, that one they could not reproduce. Sent it that plan and just to be sure opened it and now the view callouts are working. So it is some sort of sporadic issue. Expand The View name issue is still here in my current plan... and a quick test plan Didn't look into the other issues M. Link to comment Share on other sites More sharing options...
