FrozeDesignBuild Posted March 8, 2019 Share Posted March 8, 2019 Hello, We need help with making neo-angle walls. Please look at our glass shower enclosure. Where the walls meet, we get bad connections and have not been able to "join" them. What causes this? Is there a way to change Wall or Door settings to prevent this from happening? Thanks for your help, Susan. 2019-03-04_Poll_-_Master_Bath_-_proposed_bath__1.plan Link to comment Share on other sites More sharing options...
FrozeDesignBuild Posted March 8, 2019 Author Share Posted March 8, 2019 Sorry, please try this file. Thanks. 2019-03-04_Poll_-_Master_Bath_-_proposed_bath__1.plan Link to comment Share on other sites More sharing options...
FrozeDesignBuild Posted March 8, 2019 Author Share Posted March 8, 2019 Eric - Thanks for the link to prior forum. I will check out. I had searched, but could not find anything. So thanks. -Susan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 9, 2019 Share Posted March 9, 2019 Susan, I think you might have to clarify what exactly the problem is and whether you're talking about 3D connections or plan views. Link to comment Share on other sites More sharing options...
Kbird1 Posted March 11, 2019 Share Posted March 11, 2019 On 3/8/2019 at 12:03 PM, FrozeDesignBuild said: Eric - Thanks for the link to prior forum. I will check out. I had searched, but could not find anything. So thanks. -Susan The Plan View does look horrible, some of the 3 Walls are reversed ie exterior wall side is in on some and out on others with different materials , plus the is Polyline Solids at the party too...... if you assign the 3x6 tile to the walls as a material and to a Wall Cap , the polyline Solids are not needed. Ithe the walls set as railinging you shower glass is only 40" high , uncheck that box if glass is going to the Ceiling or set the appropriate height eg 84" still some wall issues though but i haven't got more time right now to figure it out.... Link to comment Share on other sites More sharing options...
Doug_N Posted March 11, 2019 Share Posted March 11, 2019 I loaded your file in x11 and this is what It looks like. I too am a bit confused about what the problem is. Link to comment Share on other sites More sharing options...
