Davidahill5050 Posted January 28, 2019 Share Posted January 28, 2019 I am having a problem when I print Elevations. All of the print is sharp and dark. Any brick that is supposed to print is very light to invisible. I have worked with line weights with no change in printing. I print a pdf. Then I send it to a kip printer. In the pdf the brick is very light. But, It does show up on the PDF. When I print the layout the brick does not print. Thanks in advance for any help. David Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 28, 2019 Share Posted January 28, 2019 You'll probably have to set the brick to be a little darker or to use a little thicker line weight to accommodate your printer. Some printers can handle lighter colors and lighter line weights better than others. The PDF is going to be "lossless" so to speak, but physical printing can vary from one setup to the next and partially depends on the setting for that printer too. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 28, 2019 Share Posted January 28, 2019 On 1/28/2019 at 9:49 PM, Davidahill5050 said: I am having a problem when I print Elevations. All of the print is sharp and dark. Any brick that is supposed to print is very light to invisible. I have worked with line weights with no change in printing. I print a pdf. Then I send it to a kip printer. In the pdf the brick is very light. But, It does show up on the PDF. When I print the layout the brick does not print. Thanks in advance for any help. David Expand Try a different PDF Printer , eg BullZip or try the Built in Chief PDF Printer and see if you get the same results , I find at time the Built in one gives different results. As a test try Printing Black and White , instead of Grayscale etc. M. Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 28, 2019 Share Posted January 28, 2019 On 1/28/2019 at 9:49 PM, Davidahill5050 said: I am having a problem when I print Elevations. All of the print is sharp and dark. Any brick that is supposed to print is very light to invisible. I have worked with line weights with no change in printing. I print a pdf. Then I send it to a kip printer. In the pdf the brick is very light. But, It does show up on the PDF. When I print the layout the brick does not print. Thanks in advance for any help. David Expand I'm going to guess you're talking about the brick mortar lines being too light in a black and white elevation in layout. In your elevation view, using the Adjust Material Definitions tool click on the brick wall and under the General panel, "Lines" option, change the mortar lines to a darker color or black, then when you close the elevation let it update your layout. Link to comment Share on other sites More sharing options...
Davidahill5050 Posted January 29, 2019 Author Share Posted January 29, 2019 Thank you for the input! Changing the mortar color makes good sense. I will try this tomorrow. Thank you again! Link to comment Share on other sites More sharing options...
