Can't see terrain in camera views
j2narchitecture
Hi.
I imported a terrain perimeter with elevation data from a .dwg file.
I can't see the terrain in any of my camera views.
I checked to make sure that a terrain perimeter was created and that each contour line has an elevation associated with it.
It does.
Attached is my .plan and the .dwg file I imported.
Many thanks in advance for any help.
I'm using X10 on my iMac.
E18-00044 SITE PLAN.dwg
test.plan
Your terrain is on a layer called BOUNDARY, so make sure that is toggled on in the camera view.
Open the Terrain Specification dbx and change the Terrain Surface Smoothing to Medium or any one except Linear.
It looks like the terrain needs some work.
Thanks for the feedback everybody. :)
Glenn:
There should only be one terrain.
In my CA plan, I got frustrated with and started to make some topography by using poly line solids. That’s the bit you see off to the left of the terrain in your pic above of the terrain you got to show up in camera view.
I am going to look at the original cad file and see if I can clean it up and then reimport it into CA.
