capitaldesigns Posted January 23, 2019 Share Posted January 23, 2019 I just started on a project where I will be tracing over an existing floor plan. The house has several areas where the walls have stepped thicknesses. I am not sure how to do this in Chief. I am also having trouble where 2 wall come together at a 45 degree angle. The corner of these walls come together with a 4" flat end. Chief wants to make this a sharp corner. How do I get a flat end of these 2 walls. I have included a snap shot of the floor plan and have circled the areas I am talking about. Any suggestions would be greatly appreciated. Thanks, Mike Link to comment Share on other sites More sharing options...
mtldesigns Posted January 23, 2019 Share Posted January 23, 2019 As far as the extra thick wall, what I did was to create a new wall type in the dbx, framed and drywall on both sides, with the gap you are needing. Might be a little PITA for the different areas you have, but this worked pretty well, and it framed like the builder wanted. Re: the 45's, you just have to keep playing with it. You might have to put in 12" flat section then an angle piece... if that takes, throw a dim on the flat and just keep widdling it down till you know you can't anymore. At least that's what I just did. Just be thankful your not using a pony wall here, CHIEF's pony and railing walls don't work the greatest. Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 23, 2019 Share Posted January 23, 2019 Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 23, 2019 Share Posted January 23, 2019 11 hours ago, solver said: Watch on YouTube: http://youtu.be/THEm4AfeoMA?hd=1 Don't know why video will not embed. Whenever your link is "youtu.be" it will not appear in the forum window. Change to the "youtube.com" address for the video. Link to comment Share on other sites More sharing options...
