LevisL Posted January 15, 2019 Share Posted January 15, 2019 I have two different vaulted ceiling peaks in this plan and I need a wall to fill in between the ceiling planes where the vaults join (where the hole is in the image). Just curious if there's any way to do this from the structure or roof tabs in the wall dbx? I've tried several different combinations of checkboxes (attic wall, roof cuts wall at bottom, stop at ceiling above, etc.), but I can't get the wall bottom to cut at the lower ceiling plane. Is it possible without editing the wall bottom in an elevation view or drawing a polyline solid instead of a wall? Vaulted Ceiling Plan.plan Link to comment Share on other sites More sharing options...
SNestor Posted January 16, 2019 Share Posted January 16, 2019 2 minutes ago, solver said: I should record these fixit sessions. Vaulted Ceiling Plan (eric).zip You should...or someone should. You showed this to me a while back...but, I could not remember how to fix it. Argggggg.... Link to comment Share on other sites More sharing options...
LevisL Posted January 16, 2019 Author Share Posted January 16, 2019 Hmmm... I wonder if it works differently on a Mac than a PC... I open up the file you attached and I see this: Link to comment Share on other sites More sharing options...
LevisL Posted January 16, 2019 Author Share Posted January 16, 2019 Got it to work. It appears to be very finicky though. The order that you adjust the ceiling planes seems to matter. Thanks Eric! Link to comment Share on other sites More sharing options...
LevisL Posted January 16, 2019 Author Share Posted January 16, 2019 2 minutes ago, solver said: I opened the plan and found what you did -- a big gap. Finicky is a polite way to describe it I hope now that I got it to work that it stays that way! Not overly optimistic yet Link to comment Share on other sites More sharing options...
Kbird1 Posted January 16, 2019 Share Posted January 16, 2019 The Ceiling plane is just not snapped to the Invisible wall properly, if you pull the ceiling plane up ( as viewed) and let it resnap as you come back down, it's all good. I believe that was the fix found in the Thread Steve and Eric are talking about from a few months ago as I remember it..... Link to comment Share on other sites More sharing options...
