tracer Posted January 8, 2019 Share Posted January 8, 2019 CAN ANYONE HELP WITH THIS? WHERE I WANT THE DOOR TO MASTER BDRM BRIDGES BETWEEN TWO WALL TYPES. ONE IS A PONY WALL THAT DEFINES A CLERESTORY SPACE AND OTHER IS A REG WALLTYPE IN A 9' CLG AREA. THANKS. STUDER CHIEF TALK 1.pdf STUDER CHIEF TALK 2.pdf Link to comment Share on other sites More sharing options...
Doug_N Posted January 8, 2019 Share Posted January 8, 2019 Just a little confused by your posting. Where is the pony wall? I can't see it in the 3d rendering. Where exactly do you want the door? It looks like there are doors in every place that you could put a door? Try posting the plan file as well. That way someone trying to help you can look at the model. Link to comment Share on other sites More sharing options...
tracer Posted January 8, 2019 Author Share Posted January 8, 2019 Thanks Doug. Enclosed a PDF and the plan file. STUDER_RES_9.4.18.plan STUDER CHIEF TALK 3.pdf Link to comment Share on other sites More sharing options...
Doug_N Posted January 8, 2019 Share Posted January 8, 2019 The plan file that you sent doesn't seem to match the image in your question. Are you trying to move the door that is circled in red? There is a wall on the other side of the wall that the door is mounted in, and moving it further to the right would interfere with that wall and the bath tub, or am I missing something here? My phone number is in my signature, maybe give me a call and we can chat about this problem? Link to comment Share on other sites More sharing options...
tracer Posted January 8, 2019 Author Share Posted January 8, 2019 Yes Doug the door you have circled is the one I want to move. That is where the pony wall and regular wall type meet and won't let me span the two. Any work around for that?? Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 8, 2019 Share Posted January 8, 2019 21 minutes ago, tracer said: Yes Doug the door you have circled is the one I want to move. That is where the pony wall and regular wall type meet and won't let me span the two. Any work around for that?? could try a point-to-point move or hold ctrl while dragging any object supersedes snaps in most cases Link to comment Share on other sites More sharing options...
joey_martin Posted January 8, 2019 Share Posted January 8, 2019 You can't put a door there, there is a wall in the way. Calling it a pony wall with the bottom half invisible doesn't not make it a wall. You probably need to delete that wall and draw the clearstorey wall on the upper/attic level. Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 8, 2019 Share Posted January 8, 2019 8 minutes ago, joey_martin said: You can't put a door there, there is a wall in the way. Calling it a pony wall with the bottom half invisible doesn't not make it a wall. You probably need to delete that wall and draw the clearstorey wall on the upper/attic level. ahh, I misunderstood the problem. @tracer Just opened your plan file, quite a few problems here, trying to figure out what's going on...give a second Link to comment Share on other sites More sharing options...
tracer Posted January 8, 2019 Author Share Posted January 8, 2019 Thanks Rennerabbit ! holding control key did work, had to cut wall for door to show but looks good. Thanks again. Joey_Martin; My clerestory space is defined with a second floor. How would I draw a clerestory wall? Tried to make the wall full height but still wouldn't let door in. STUDER CHIEF TALK SOLUTION.pdf Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 8, 2019 Share Posted January 8, 2019 1 hour ago, tracer said: Yes Doug the door you have circled is the one I want to move. That is where the pony wall and regular wall type meet and won't let me span the two. Any work around for that?? is this a parapet roof at the clear story? Link to comment Share on other sites More sharing options...
tracer Posted January 8, 2019 Author Share Posted January 8, 2019 No, Rene it is a 4 way hip roof @ 1/4"/12" pitch. Link to comment Share on other sites More sharing options...
Renerabbitt Posted January 8, 2019 Share Posted January 8, 2019 35 minutes ago, tracer said: No, Rene it is a 4 way hip roof @ 1/4"/12" pitch. A few problems in this file still to work out. Something to note for split level or multiple ceiling heights, make sure to get all of your construction assembly defaults set. Your roof planes were at a lower elevation than the room ceiling heights. Also instead of setting up pony wall assemblies, try and set your exterior wall at the room with the heigher ceiling height and in the wall DBX go to the roof tab and check "lower wall type if split by butting roof" and assign your interior wall to the drop down menu. Still some things to fix in this plan but maybe a good start? I deleted your sloped roof, I assumed a parapet, for the purpose of con docs you could leave it and specify the method for sloping(sister/wedge/shaving) Keep in mind the roof assembly was using 2x4's and your ceiling assembly is using 2x6 and the 2 are still at opposing elevations. STUDER.plan Link to comment Share on other sites More sharing options...
