snoopy1963 Posted December 21, 2018 Share Posted December 21, 2018 (edited) Whenever I send an elevation to the layout, the siding shows through material in front of it. In my case the siding shows through the window trim, corner trim, & water table trim board. See attached image. I've tried numerous ways to trouble shoot the problem but can't find a solution. This only happens on the side elevations. Front and rear elevations are okay. Need help if you have encountered a similar situation. Thanks, Roland Archi-Dinamica Architects, LLC New Orleans ral@archid-llc.com Edited December 21, 2018 by snoopy1963 more specifics Link to comment Share on other sites More sharing options...
Chopsaw Posted December 21, 2018 Share Posted December 21, 2018 It could be a setting or a bug. No way of telling without a plan file or a small test plan that is behaving the same way. Also need to know what version of the software you are running and then someone can help. I have had some layering issues with plot lines in X10 that can sometimes be refreshed by opening and closing the view. Link to comment Share on other sites More sharing options...
javatom Posted December 21, 2018 Share Posted December 21, 2018 You may have your wall definition siding thicker than the window trim. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 21, 2018 Share Posted December 21, 2018 Check the windows specification dialog - Options Tab and make sure the windows are not marked "Recessed", on siding such a setting could cause these phenomena. DJP Link to comment Share on other sites More sharing options...
