Chris_Kelly Posted December 10, 2018 Share Posted December 10, 2018 Are there default settings for electrical connections? The reason I'm looking for them is that when I make a lighting plan I always adjust all the connection splines to have a larger radius (make them straighter) than what Chief gives them when they are put in the drawing. It would save me a good 10 minutes on an average house just adjusting those damn splines. So does anyone know where the defaults are or have a work-around for me? Please and thank you. Link to comment Share on other sites More sharing options...
joey_martin Posted December 10, 2018 Share Posted December 10, 2018 Don't use those connections. Just use a CAD spline to have greater control. Have the current CAD layer set to Connections, Electrical. 1 Link to comment Share on other sites More sharing options...
chief58 Posted December 11, 2018 Share Posted December 11, 2018 5 hours ago, Chris_Kelly said: Are there default settings for electrical connections? The reason I'm looking for them is that when I make a lighting plan I always adjust all the connection splines to have a larger radius (make them straighter) than what Chief gives them when they are put in the drawing. It would save me a good 10 minutes on an average house just adjusting those damn splines. So does anyone know where the defaults are or have a work-around for me? Please and thank you. I have suggested the ability to draw the electrical connection like the spline lines but nothing yet, like you I have to select them to straigtren them out time consuming, I like using the electrical connection lines so if I do a plan check it will tell me if I don't have something connected so I can fix it I don't think you get that with Joey way of doing it, I have done it that way when I put a lighting plan and an electrical plan on different pages Link to comment Share on other sites More sharing options...
KevinWaldron Posted December 12, 2018 Share Posted December 12, 2018 Speaking of electrical connections another question related. Any of you guys show fire/smoke detectors and show them connected per code? If so how do you show connection with fire/smoke detectors that are on a second floor or vise vs? Link to comment Share on other sites More sharing options...
chief58 Posted December 12, 2018 Share Posted December 12, 2018 I show them but just note that they are battery backup and interconnected per code Link to comment Share on other sites More sharing options...
Kelly_K Posted December 17, 2018 Share Posted December 17, 2018 On 12/10/2018 at 12:09 PM, Chris_Kelly said: Are there default settings for electrical connections? The reason I'm looking for them is that when I make a lighting plan I always adjust all the connection splines to have a larger radius (make them straighter) than what Chief gives them when they are put in the drawing. It would save me a good 10 minutes on an average house just adjusting those damn splines. So does anyone know where the defaults are or have a work-around for me? Please and thank you. I wish there were. Do a search in suggestions you'll find a long list of people asking for improvements including myself. Pick a thread and add your name is what I would recommend. Link to comment Share on other sites More sharing options...
