capitaldesigns Posted December 10, 2018 Share Posted December 10, 2018 I am working on a project that the living room is 12" lower than the entry. When I do a 3D view looking from the living room towards the raised entry it shows the edge of the concrete slab. It should be showing drywall. The baseboard shows correctly. Above the base board shows gray concrete. Does anyone know how to correct this ? Thanks, Mike Link to comment Share on other sites More sharing options...
Chopsaw Posted December 10, 2018 Share Posted December 10, 2018 I think I understand the visual but a plan file would help immensely in a situation like this. How is the living room defined ? Link to comment Share on other sites More sharing options...
capitaldesigns Posted December 10, 2018 Author Share Posted December 10, 2018 Both the living room and entry defined as such and under floor structure is called out as concrete slabs. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 10, 2018 Share Posted December 10, 2018 Can you have the entry as NOT a Mono Slab and put 12" of concrete into the floor structure of the room ? If not you may be ahead of me because I don't have baseboard with the mono slab. Something like this ? Link to comment Share on other sites More sharing options...
glennw Posted December 10, 2018 Share Posted December 10, 2018 I assume that you want the drywall to extend down and cover the face of the concrete step? You can do this by setting the Brick Ledge depth to 12" in the Wall Type Definitions dbx. The problem is that the baseboard builds hard up against the concrete and not the wall lining. So you would then need to do the skirting manually with a molding polyline. I would never build it like that. I would always take the wall down to the lower slab to allow for any adjustments to irregularities in the concrete pour. Like this: Link to comment Share on other sites More sharing options...
