rockyshepheard Posted November 18, 2018 Share Posted November 18, 2018 I am struggling with this hip roof that is in line with the edge of the overhang. please see image. Must I do this manually or is there a way to do this automatically? I've tried many ways to do it manually. Can some roof guru please assist? Many thanks! Link to comment Share on other sites More sharing options...
Kbird1 Posted November 18, 2018 Share Posted November 18, 2018 10 minutes ago, rockyshepheard said: I am struggling with this hip roof that is in line with the edge of the overhang. please see image. Must I do this manually or is there a way to do this automatically? I've tried many ways to do it manually. Can some roof guru please assist? Many thanks! Maybe with invisible walls? But if you want help , you'll need to post the plan , add the .plan file to a post , just make sure it isn't open in Chief when you do it as Chief locks the file. If the File is over 25mb you can try Zipping it 1st before posting. Note: the posted Image is very hard to see any details on due to size and Colours used. Also, it's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too .............. See mine below in Blue for how to do that. If you don't see my Signature below then you have them turned off for the Forum, so you need to Toggle it on by going to the Upper RH Corner of this Forum Window ^^^^ and Clicking on your Username and making sure Signature is enabled (green) and then Add your Own Sig. too : UserName> Account > Signatures M. 1 Link to comment Share on other sites More sharing options...
glennw Posted November 19, 2018 Share Posted November 19, 2018 Yes, can be done with invisible walls as Mick says. The trick is to know where to place the walls and what to do next. Place the invisible walls to define the area of your raised roof - ignore the walls you have already drawn to define your rooms. Raise the ceiling height of the rooms defined by your invisible walls and your real walls. One critical thing is the placement of the invisible wall that defines how far back the raised ceiling heights go. It needs to be back at least as far as where the side invisible walls meet the valleys. Have a play and you will see what I mean Leave auto roofs and split screen on as you do this and you will see the effects as you change things. Link to comment Share on other sites More sharing options...
rockyshepheard Posted November 19, 2018 Author Share Posted November 19, 2018 Thanks Glennw. The roof looks correct but under the roof there should be an entry way. If I use invisible walls I don’t get that feature. Link to comment Share on other sites More sharing options...
glennw Posted November 19, 2018 Share Posted November 19, 2018 You probably need to make the entry porch a room with an invisible wall across the front. You don't need the invisible walls if there are normal walls there to define the area of the raised roof. My pictures are just generic to indicate the method. In this pic, the ceiling height of the porch and the room defined by invisible walls just inside the porch are higher than the rest of the house. Once again, the important thing is how far back you place the rear invisible wall - or the rear wall of the porch if you don't need the invisible walls inside the house. If you still can't get it, post the plan and I will show you how to do it. Link to comment Share on other sites More sharing options...
rockyshepheard Posted November 19, 2018 Author Share Posted November 19, 2018 Hi Glenn, I managed to get one in but doing the same thing on the left of the plan gave no roof at all. Very strange. I'd appreciate it if you could comment. Thanks, Rocky question.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted November 19, 2018 Share Posted November 19, 2018 7 minutes ago, rockyshepheard said: Hi Glenn, I managed to get one in but doing the same thing on the left of the plan gave no roof at all. Very strange. I'd appreciate it if you could comment. Thanks, Rocky question.plan Auto Roofs is turned Off in your plan that is all Link to comment Share on other sites More sharing options...
rockyshepheard Posted November 19, 2018 Author Share Posted November 19, 2018 Thanks you all! Link to comment Share on other sites More sharing options...
