mdarch47 Posted November 6, 2018 Share Posted November 6, 2018 Looking for help with bay window settings. See attached X10 existing conditions plan and marked up .jpg render. I am getting some odd behavior with the bay window angled side walls extending below the window seat. These are inserted bay windows and I have played around with all of the settings but must be missing something. I will probably just redraw these as a small room but wondered if it was something simple I am missing. Thanks for any guidance. Mike Dolce, Architect 1808EX_-_Copy.plan Link to comment Share on other sites More sharing options...
Gawdzira Posted November 6, 2018 Share Posted November 6, 2018 This has to do with the placement of the foundation wall that is under your brick veneer layer. You may need to fake the foundation info to get the 3d model to correct. Someone smarter than me might have a better solution. Link to comment Share on other sites More sharing options...
DougMaddox Posted January 16, 2019 Share Posted January 16, 2019 Does anyone have an answer to this? Same problem here on raised floor bay window. Denny_Jr_Remodel.plan Link to comment Share on other sites More sharing options...
Kbird1 Posted January 16, 2019 Share Posted January 16, 2019 On 1/16/2019 at 2:30 PM, DougMaddox said: Does anyone have an answer to this? Same problem here on raised floor bay window. Denny_Jr_Remodel.plan It's not the Raised Floor Doug , your Bow window doesn't seem to have enough Depth , once I pulled it out a few inches it fixed itself. The Bow Window automatically make the main wall a Pony wall which you need to set the lower wall to the Main Wall Type as well. The Red circles are where you have some Broken walls and alignment issues too. (both sides of the house actually) Edit: just found you have a 3"-4" high pony wall between the foundation and main wall on that side of the house too, and the Bow Window is in it it appears , not the main wall of the house.... 2nd pic. Mick. Link to comment Share on other sites More sharing options...
DougMaddox Posted January 18, 2019 Share Posted January 18, 2019 Thanks, Mick for the help. A second eye always helps. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 18, 2019 Share Posted January 18, 2019 26 minutes ago, DougMaddox said: Thanks, Mick for the help. A second eye always helps. No Problem.....not 100% sure if it was the Ponywall causing the Issue or the Bow Window Depth in the End , not sure why the 4" high Ponywall was there and didn't notice it at first M. Link to comment Share on other sites More sharing options...
