Cheryl_C_Crane Posted September 17, 2018 Share Posted September 17, 2018 I searched this forum for the answer to this, please accept my apologies if it has already been discussed. I would think that this has happened a lot. I have a tall pantry cab 24"d of a grey color next to a Wall cab 12"d in White. I can't seem to have 2 different molding colors - which is what our customer wants. Please see the attached file and screenshots. The young men that are remodeling this home for sale want renderings to use in the listing. Of course, there is no problem ordering the molding materials. It renders correctly in 20-20 (UGH). Cleveland Modified Kit.zip Link to comment Share on other sites More sharing options...
Kbird1 Posted September 18, 2018 Share Posted September 18, 2018 You can turn the Crown/moldings Off on the Cabinets around the Fridge Cheryl and use a molding Line 93-94" ? off the floor snapped to the Cabinets with the crown and Finshed Stock using the same Molding PL Stock instead. M. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted September 18, 2018 Share Posted September 18, 2018 If you just change the molding height on the pantry by 1/16" up or down it will disconnect from the other molding and it will be treated individually. No one will notice the slight 1/16" position change. Link to comment Share on other sites More sharing options...
rlackore Posted September 18, 2018 Share Posted September 18, 2018 16 hours ago, solver said: See if this helps. Eric's trick of copying/renaming the molding seems the most elegant solution. Plus, it's an interesting tidbit that gives some insight into how Chief works, which may be useful in other situations. Link to comment Share on other sites More sharing options...
Cheryl_C_Crane Posted September 18, 2018 Author Share Posted September 18, 2018 30 minutes ago, TheKitchenAbode said: If you just change the molding height on the pantry by 1/16" up or down it will disconnect from the other molding and it will be treated individually. No one will notice the slight 1/16" position change. Perfect & EASY! It's my understanding that CA engineers are working on a way to have cabinet moldings go on more like the real world and the schedule show the totals for each profile and color. Hope so. Thanks for all who responded! Link to comment Share on other sites More sharing options...
