ArchiMiles Posted August 30, 2018 Share Posted August 30, 2018 (edited) Edited November 1, 2025 by ArchiMiles would rather delete it Link to comment Share on other sites More sharing options...
ArchiMiles Posted August 30, 2018 Author Share Posted August 30, 2018 Done. I've looked at Distribution Path. Any tutorials on it? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 30, 2018 Share Posted August 30, 2018 18 minutes ago, ArchiMiles said: Done. I've looked at Distribution Path. Any tutorials on it? Try the F1 Key Experiment I'm not a big fan of the Tutorials because they tend to deal with only the simplest cases. 1 Link to comment Share on other sites More sharing options...
ArchiMiles Posted August 30, 2018 Author Share Posted August 30, 2018 31 minutes ago, Joe_Carrick said: Try the F1 Key I guess it's different on a Mac. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 30, 2018 Share Posted August 30, 2018 1 minute ago, ArchiMiles said: I guess it's different on a Mac. Whatever the "Help" key is. Or just open Help and search for "Distributed Path" Link to comment Share on other sites More sharing options...
Kbird1 Posted August 30, 2018 Share Posted August 30, 2018 this may help get you started.... https://www.chiefarchitect.com/videos/watch/2424/distributing-objects-along-a-path-or-region.html more info about page 1004 of the Ref.Manual Link to comment Share on other sites More sharing options...
ArchiMiles Posted August 30, 2018 Author Share Posted August 30, 2018 1 hour ago, Kbird1 said: this may help get you started.... https://www.chiefarchitect.com/videos/watch/2424/distributing-objects-along-a-path-or-region.html more info about page 1004 of the Ref.Manual THANK YOU Kbird1 !! Link to comment Share on other sites More sharing options...
Kbird1 Posted August 30, 2018 Share Posted August 30, 2018 1 hour ago, ArchiMiles said: THANK YOU Kbird1 !! No problem , to get the best help here , it is best to fill in your Signature too , see mine in Blue below for how..... Am assuming you have X10 but ????? M. Link to comment Share on other sites More sharing options...
ArchiMiles Posted September 5, 2018 Author Share Posted September 5, 2018 Yes Link to comment Share on other sites More sharing options...
BryceEngstrom Posted September 5, 2018 Share Posted September 5, 2018 It's all possible, but not easy. Distributed object is a good way to get started, but keep in mind, your seat model will want to have just one arm, then you'll need to add just the arm by itself at the start/end of each row. The bigger challenge is more the vertical placement of them and working out all the stair/floor levels. 1 Link to comment Share on other sites More sharing options...
Kbird1 Posted September 6, 2018 Share Posted September 6, 2018 On 9/5/2018 at 3:43 PM, BryceEngstrom said: It's all possible, but not easy. Distributed object is a good way to get started, but keep in mind, your seat model will want to have just one arm, then you'll need to add just the arm by itself at the start/end of each row. The bigger challenge is more the vertical placement of them and working out all the stair/floor levels. Nicely done Bryce ! There you go Archi , save yourself some time and buy an Auditorium Symbol off Bryce 1 Link to comment Share on other sites More sharing options...
DougMaddox Posted September 6, 2018 Share Posted September 6, 2018 Look under "auditorium" in the library. All you need is there. 2 Link to comment Share on other sites More sharing options...
ArchiMiles Posted September 9, 2018 Author Share Posted September 9, 2018 Thanks for all the help!! Link to comment Share on other sites More sharing options...
