Joe_Carrick Posted August 3, 2018 Share Posted August 3, 2018 Why does this exist in both the Plan and the Layout? It seems to me that having it in the Plan is superfluous. It's useful in the Layout for title block fill-in but I don't understand why it needs to be in the Plan. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 3, 2018 Share Posted August 3, 2018 I think @jbaehmer has a template system that uses it to populate the layout title block straight from the plan file but he could explain it better. I have often wondered why there is not an option or easier way to transfer the data from plan to layout or a default Designer Info. Link to comment Share on other sites More sharing options...
dshall Posted August 3, 2018 Share Posted August 3, 2018 1 hour ago, Joe_Carrick said: Why does this exist in both the Plan and the Layout? It seems to me that having it in the Plan is superfluous. It's useful in the Layout for title block fill-in but I don't understand why it needs to be in the Plan. I use both, Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2018 Author Share Posted August 3, 2018 2 hours ago, dshall said: I use both, Where do you access in the Plan? Do you ever have a different set of info in the Plan than in the Layout? The reason I ask is that I only use the built-in macros for this information in the Layout. ei: Title Block fill-in. Link to comment Share on other sites More sharing options...
dshall Posted August 3, 2018 Share Posted August 3, 2018 in layout I use it for the title block, in plan I use it under clients name on sheet one... not a big deal, several ways of achieving the same thing.... with macros... Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 3, 2018 Author Share Posted August 3, 2018 2 hours ago, dshall said: in layout I use it for the title block, in plan I use it under clients name on sheet one... What is Sheet 1 of the Plan ??? Please explain this. Don't you mean Sheet 1 of the Layout - or maybe even Sheet 0 ? Link to comment Share on other sites More sharing options...
dshall Posted August 3, 2018 Share Posted August 3, 2018 yes Link to comment Share on other sites More sharing options...
dshall Posted August 3, 2018 Share Posted August 3, 2018 7 hours ago, Joe_Carrick said: ...... It seems to me that having it in the Plan is superfluous. ..... Joe, it is not a big deal, all I was saying is I do not think it is superfluous, but if they think it is, they can eliminate it, there are other way of accomplishing what I am doing. Link to comment Share on other sites More sharing options...
