acnewton12 Posted July 19, 2018 Share Posted July 19, 2018 Hello! Has anyone had issues with their 1/4" scaled documents not actually printing in 1/4" scale? I've tried it 4 different ways now and no matter what, my printed drawings are off by 12" (in scale). I've eliminated margins, printed from PDF, printed from layout, and nothing has worked. Help! Link to comment Share on other sites More sharing options...
lbuttery Posted July 19, 2018 Share Posted July 19, 2018 Hi: this should not be an issue you must have a setting off please change your signature to include Chief ver etc also include screen captures of the various settings to get better advice you can also contact CA's tech support for assistance Lew Link to comment Share on other sites More sharing options...
Chopsaw Posted July 19, 2018 Share Posted July 19, 2018 Most likely you are set to "Fit to Paper" make sure you are set "To Scale:" Link to comment Share on other sites More sharing options...
acnewton12 Posted July 19, 2018 Author Share Posted July 19, 2018 Thanks for the quick replies! Chopsaw, I did recheck the "fit to paper" setting and it is set "to scale". Attached is a photo of my settings. I'm using X9. Link to comment Share on other sites More sharing options...
Kbird1 Posted July 19, 2018 Share Posted July 19, 2018 Are you sure you sent to layout at 1/4" and not fit to sheet ? Link to comment Share on other sites More sharing options...
Chopsaw Posted July 19, 2018 Share Posted July 19, 2018 Ok that looks fine so then when you print from Adobe select "Actual Size" and if that does not work then it is a margins issue. And Mick may have nailed it as your DBX does not show the scale when you have it selected. Link to comment Share on other sites More sharing options...
