Wall spec problem
Scottb
I created my own template for a brick house.  If I change a wall to siding 4, the wall will still show the brick material. Anybody have any advise?  the siding on my siding 4 should be white hardi board.
 See picture. 5b4d07171b316_Screenshot2018-07-1616_58_42.thumb.png.02969eca25d4e8229fa8b61c789207ca.png
I am not sure this effect is normal, if you switch wall types it should automatically change the material to the correct type and thickness , it is certainly happening in your template though.... I think Robert is correct , (nice catch )  you have overridden the Wall's Materials Defaults using the wall specification DBX even though the Default Brick is Rosewood for that wall, you also set it manually on the materials tab so when you goto change to siding it stays rosewood due to you manually setting it that way , so only the thickness changes.
When I checked the materials , I didn't notice at 1st that the word Default was missing from the Rosewood brick material see below after resetting it...
