1-3-2-4 Posted July 10, 2018 Share Posted July 10, 2018 As the title says, I have terrain data from my surveyor...northings, eastings, z data. What's the best way to enter this information into the software to generate 3D terrain? Will be very helpful in laying out the house. Thanks! Link to comment Share on other sites More sharing options...
Kbird1 Posted July 10, 2018 Share Posted July 10, 2018 What kind of Data you have ? from the Surveyor may determine the input method... if you have DWG or DXF Autocad files you can import them.... assuming it is in the right Format https://www.chiefarchitect.com/support/article/KB-00719/importing-terrain-elevation-data-from-a-dxf-or-dwg-file.html Link to comment Share on other sites More sharing options...
Chopsaw Posted July 10, 2018 Share Posted July 10, 2018 XYZ Data can also be imported from a simple text file or entered manually but the text file allows you to keep the data a little more organized. If that is your situation I will try to look up the details and procedure from last time I did it. Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 11, 2018 Author Share Posted July 11, 2018 Thanks for the responses. I have .txt files. They look something like this: 23,575774.9400,2703326.8677,538.640,GPS HUB SET 23 24,575774.9809,2703326.8573,538.634,CHK HUB 23 25,575740.3110,2703118.5270,545.760,GPS HUB SET 25 26,575740.3193,2703118.5342,545.781,CHK HUB 25 27,573794.5342,2703628.8940,454.421,PROBE 28,573846.3163,2703614.6166,455.880,PROBE 29,573835.5458,2703620.4183,455.286,PERC 30,573822.6904,2703627.5739,454.909,PERC 31,573807.8712,2703636.3310,455.429,PERC 32,573804.2540,2703627.1311,454.342,PERC 33,573832.0943,2703614.2048,454.890,PERC 34,573815.2540,2703616.5563,454.350,PERC ? The data is structured like this: Point ID, X coordinate, Y coordinate, elevation with respect to sea level (ft). The X and Y coordinates reference the Pennsylvania State Plain (south). Link to comment Share on other sites More sharing options...
glennw Posted July 11, 2018 Share Posted July 11, 2018 File...Import...Import Terrain Data... Continue...select the file...select #XYZ Description (comma delimited) Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 11, 2018 Author Share Posted July 11, 2018 OK, so the order is XYZ? Turns out the data I just posted is mixed up (YXZ). It's presently Point ID, Y coordinate, X coordinate, elevation with respect to sea level (ft). Link to comment Share on other sites More sharing options...
1-3-2-4 Posted July 11, 2018 Author Share Posted July 11, 2018 Yeah, that's easy. Just wanted to confirm! Link to comment Share on other sites More sharing options...
glennw Posted July 12, 2018 Share Posted July 12, 2018 Or in the Import Terrain Asistant dbx, use #YXZ Description (comma delimited) Link to comment Share on other sites More sharing options...
