bkjernis Posted July 4, 2018 Share Posted July 4, 2018 When I place grouped furniture like a kitchen table and chairs they are at different heights. I am using absolute reference locations on some objects because slabs and furniture ended up changing their initial elevations. Does using absolute reference locations on objects cause the problem? Thanks Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 4, 2018 Share Posted July 4, 2018 If you want symbols to be placed relative to a room's floor, you would use "Floor" as the reference and not absolute. Honestly, I have not studied the exact definitions of "Absolute" in terms of what that actually means. I take into consideration if I want something located on terrain, I use the "terrain" setting, within a room, I use "Room" because I do not know what is meant by "Absolute" in this software. A good thing to get defined and understood, eh? DJP Link to comment Share on other sites More sharing options...
bkjernis Posted July 4, 2018 Author Share Posted July 4, 2018 Here is a picture. Link to comment Share on other sites More sharing options...
DavidJPotter Posted July 4, 2018 Share Posted July 4, 2018 Like I said above, perhaps "absolute" is not appropriate but "Room" is, try that. DJP Link to comment Share on other sites More sharing options...
glennw Posted July 5, 2018 Share Posted July 5, 2018 David, Absolute relates heights to Chiefs zero floor level which is the default OOB floor 1 level. Link to comment Share on other sites More sharing options...
Renerabbitt Posted July 5, 2018 Share Posted July 5, 2018 On 7/4/2018 at 8:45 AM, bkjernis said: Here is a picture. Also looks like you may have set the room to be a garage, common problem with placing furniture that has to do with the way chief handles curbs (stem walls extended past a slab) As an example, change any room to a garage type and set the floor height to 0 and try and place furniture..wonky! Link to comment Share on other sites More sharing options...
