Gawdzira Posted June 29, 2018 Share Posted June 29, 2018 I am having issues (long story). But this problem in CA is probably the one that can be solved without a Doctorate in Psychology. See the images and plan. My balcony railing is causing a break in the wall connection of some sort. Please show me this easy fix and make it so easy I am embarrassed. DOL_DD_V1ss.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted June 29, 2018 Share Posted June 29, 2018 Use Edit Wall Layer Intersections and just drag all the layers back to outside your siding. That exterior corner there looks like it could use a little Wall Layer Intersection work as well. Link to comment Share on other sites More sharing options...
Richard_Morrison Posted June 29, 2018 Share Posted June 29, 2018 The program shouldn't do this, but to fix it, just put a short room divider wall between the railing and the main wall. Link to comment Share on other sites More sharing options...
glennw Posted June 30, 2018 Share Posted June 30, 2018 Pull the railing end away from the corner and then drag it back again. Link to comment Share on other sites More sharing options...
