madcowscarnival Posted June 25, 2018 Share Posted June 25, 2018 Taking a wild swing for the fences. Does Chief have the capacity to produce a lighting plan? Something like a grid layout on a parking lot, with lumens at each point on the grid based on a specific light source? I realize this is pretty esoteric, and I'm fairly surprised that this particular City still requires this, but maybe as Chief does so much high-level modeling with lighting sources, positions, etc. it can produce something similar. Thank you ahead of time. Link to comment Share on other sites More sharing options...
madcowscarnival Posted June 25, 2018 Author Share Posted June 25, 2018 Photometric plan would be a more accurate description. Link to comment Share on other sites More sharing options...
glennw Posted June 26, 2018 Share Posted June 26, 2018 Do you want just a pretty 3D picture or do you need to do the actual calculations and show the values. Chief can do the first, but not the second. Link to comment Share on other sites More sharing options...
Electromen Posted June 26, 2018 Share Posted June 26, 2018 Chief can't do what they require. I get them done free by the local lighting supplier. Link to comment Share on other sites More sharing options...
glennw Posted June 27, 2018 Share Posted June 27, 2018 Here is a program with a 30 day trial period that can do what you require. http://www.lightingreality.com/Home/tabid/1805/Default.aspx Link to comment Share on other sites More sharing options...
rlackore Posted June 27, 2018 Share Posted June 27, 2018 Chief won't do it automatically. If the township needs a photometric plan, it's easiest (in Chief) to download the manufacturer's isoplots and hand-jamb it the old-fashioned way, but obviously you need to lock in the manufacturer, lamp type, output, spacing, mounting height, distribution, etc. As far as representing the lighting in 3D, you can only approximate things, but if you spend enough time you can get close. Here's a Lithonia KAD LED fixture with a Type III distribution, 4000K color temperature, 35 watts (4200 lumens) on a 10' pole: 1 Link to comment Share on other sites More sharing options...
