Single Wall Refuses to Frame?
WoodlandDesign
I've played around with this quite a bit and don't see what I'm doing incorrectly.  The second floor north wall (top of screen) will not frame for me and I don't know why.  All the other walls have done so without trouble.
I've manipulated the wall connections, checked and double-checked wall properties, etc., nothing seems to help.  I don't remember having this problem ever before.
Any input would be appreciated.
Thanks in advance for your help.
3832_Aldrich_Proposed_Plan_E.plan
If you remove the end wall truss above it will frame.  Not sure if there was a reason to have it there or why that side of the building is framed differently than the other.  I usually build the walls first and don't seem to run into that issue.
  • Upvote 2
