Spectrum-Design Posted June 17, 2018 Share Posted June 17, 2018 I have a laptop that I use at home which does not support a high enough version of Open GL for Cheif X. I can do enough in plan to make it worthwhile to use the laptop, regardless of the video card. I get this pop-up window a lot: C:\p4sync\dev\Releases\20\chief\source\appmgr.cpp(1031): Error #272032208 "You are using a video card that will not give you optimal performance from this product. Ensure that your video card meets the minimum system requirements and that you are using an up to date video card driver." 6/17/2018 6:20:40 PM Build: 20.3.0.54x64 Is there anyway to disable this nag window? Link to comment Share on other sites More sharing options...
DavidJPotter Posted June 17, 2018 Share Posted June 17, 2018 The only way I know of is to obtain and install one that does meet minimum requirements, period. DJP Link to comment Share on other sites More sharing options...
Spectrum-Design Posted June 18, 2018 Author Share Posted June 18, 2018 I get this all the time too: Assertion failed: A serious error occurred. Do not save the file in its current state. If you want to try saving your work, use Save As to create a new file. Please restart the program and contact Technical Support. C:\p4sync\dev\Releases\20\chief\source\ChiefQtApplication.cpp(238): Error #272000999 "A serious error occurred. Do not save the file in its current state. If you want to try saving your work, use Save As to create a new file. Please restart the program and contact Technical Support." 6/17/2018 10:20:51 PM Build: 20.3.0.54x64 Thanks David. I know I've read about solutions to change something in the registry to keep nag windows like that from popping up in other programs. I don't know enough about registries or anything that technical to know if that is possible in this circumstance though. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 18, 2018 Share Posted June 18, 2018 If it is an intel Card / Driver , try searching on Intel here in the Q&A Forum as there are numerous versions of intel's drivers not working well with Chief with certain Intel Cards and there have been several good threads on it with MarkMC and Kitchenabode taking part. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted June 18, 2018 Share Posted June 18, 2018 If memory serves me correctly, Intel integrated chips less than HD4000 will not support CA's Open GL needs. There is no way to update these older HD chips. Time for a new laptop. Link to comment Share on other sites More sharing options...
