BlueTree Posted May 29, 2018 Share Posted May 29, 2018 Attempting to create a exterior double door with side panels. Panels styles (lites) match the door style. How do i do this so that all match? Lites are not an option under door specs. Link to comment Share on other sites More sharing options...
MarkMc Posted May 29, 2018 Share Posted May 29, 2018 Copy the door, swing it closed, turn off all the hardware. Had to do this an hour ago. Link to comment Share on other sites More sharing options...
BlueTree Posted May 29, 2018 Author Share Posted May 29, 2018 This is what I am trying to create. Have the door. Lites or side panels?? not sure of correct term here. Link to comment Share on other sites More sharing options...
DavidJPotter Posted May 29, 2018 Share Posted May 29, 2018 What Mark Mc suggested would be the easiest way but if you want something that really looks nice and representative you will probably have to draw custom muntins to get just the exact look you want. It depends on how far you will go to gain just the right effect. DJP Link to comment Share on other sites More sharing options...
MarkMc Posted May 30, 2018 Share Posted May 30, 2018 4 hours ago, BlueTree said: This is what I am trying to create. Have the door. Lites or side panels?? not sure of correct term here. To get the stiles of the sidelites you'll need to open the symbol and add stretch planes, may need to do go through a generation. There also a way to make door symbols using a wall cabinet. Posts in tips or symbol section from a year or two ago. The glass is another story as David notes. Link to comment Share on other sites More sharing options...
CJSpud Posted May 31, 2018 Share Posted May 31, 2018 Not exactly a duplicate but "reasonably" close .... assembled using Library components. Link to comment Share on other sites More sharing options...
BlueTree Posted June 8, 2018 Author Share Posted June 8, 2018 thx gentlemen Link to comment Share on other sites More sharing options...
