Renerabbitt Posted May 7, 2018 Share Posted May 7, 2018 I've ran into this problem before and don't remember the solution. Working on this kitchen design and the cln'g mat'l is being such a nuisance. Id prefer presenting this particular kitchen in PBR as the levels of sheen really make this stand out in a way that I can't achieve in regular 3d view. 554 MINER RD goofing.plan Link to comment Share on other sites More sharing options...
HumbleChief Posted May 7, 2018 Share Posted May 7, 2018 Rene, Try removing the 3/4" knotty oak from the roof surface layer and just use the white T&G from the ceiling finish. Nah that didn't work - still shows in another part of the kitchen and wrecks your eave structure. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 7, 2018 Author Share Posted May 7, 2018 5 minutes ago, HumbleChief said: Rene, Try removing the 3/4" knotty oak from the roof surface layer and just use the white T&G from the ceiling finish Just tried your suggestion. Triangles still exist even if I remove all texture files from the cln'g mat'l. Maybe it has to do with insufficient lighting. I haven't dug in on this one yet but thought someone might save me the time if they had encountered something similar. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted May 7, 2018 Share Posted May 7, 2018 I just took a quick look and I think it has something to do with the exterior top plates, the wall finish is not covering them and it looks like there is a gap up there. Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 7, 2018 Author Share Posted May 7, 2018 10 minutes ago, TheKitchenAbode said: I just took a quick look and I think it has something to do with the exterior top plates, the wall finish is not covering them and it looks like there is a gap up there. I almost sent you a PM before I posted this b/c I figured you would have the solution; Of course as soon as I read your response I thought "DOH!, he's right," but alas, I manually dragged the walls up and the problem still exists. I agree that joinery would be my first assumption for this sort of thing, but it reminds me of a poly face issue I've had before. I guess I will have to dig into this one myself when I can find the patience Link to comment Share on other sites More sharing options...
HumbleChief Posted May 7, 2018 Share Posted May 7, 2018 Wow that is stubborn. I can get the large triangle to go away a couple different ways, lowering the roof and changing the walls from balloon through ceiling to stop at ceiling, but that little triangle over the sink area persists. Link to comment Share on other sites More sharing options...
HumbleChief Posted May 7, 2018 Share Posted May 7, 2018 Rene, I changed the room's ceiling finish to the 7/8" T& G, deleted the Ceiling finish in the roof dbx, and then checked use Room Ceiling Finish in the Roof Structure dbx - it seemed to work. 1 Link to comment Share on other sites More sharing options...
Renerabbitt Posted May 7, 2018 Author Share Posted May 7, 2018 2 minutes ago, HumbleChief said: Wow that is stubborn. I can get the large triangle to go away a couple different ways, lowering the roof and changing the walls from balloon through ceiling to stop at ceiling, but that little triangle over the sink area persists. You're the man, thank you for the effort. This plan is such a mess, I was in such a rush, saved me! Link to comment Share on other sites More sharing options...
