DianeP Posted April 26, 2018 Share Posted April 26, 2018 How do I put a concrete roof with overhang on a structure. Using CA x10. Link to comment Share on other sites More sharing options...
solver Posted April 26, 2018 Share Posted April 26, 2018 Thick ceiling plane. 1 Link to comment Share on other sites More sharing options...
misterwiley Posted April 26, 2018 Share Posted April 26, 2018 I believe it would be easiest to create a roof plane with a pitch of 0, a baseline height of your desired ceiling height, and then modify the structure of the roof plane to only include one material of concrete set to the desired thickness. Then you can modify the roof plane boundary lines in plan view to overhang your building as desired. 1 Link to comment Share on other sites More sharing options...
solver Posted April 26, 2018 Share Posted April 26, 2018 On second thought, a ceiling plane may not work -- roof plane like Kyle suggest is probably best. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted April 26, 2018 Share Posted April 26, 2018 Yes Roof Plane is the way to go, 0 out surface and make structure 8" or so of concrete. 1 Link to comment Share on other sites More sharing options...
DianeP Posted April 26, 2018 Author Share Posted April 26, 2018 Thanks everyone! Kyle you were very helpful and Chopsaw you got just what I was wanting to achieve. Link to comment Share on other sites More sharing options...
