Christina_Girerd Posted April 18, 2018 Share Posted April 18, 2018 I notice that when I mull an exterior door with side lites, chunks of siding disappear at the bottom - see photo below. Not quite sure how to describe it, but as soon as a break apart the mulling, the problem disappears and it looks normal. Is there something I'm doing wrong, or is this a bug? I noticed that Mark had a post today about issues with mulling interior doors, but wasn't sure if it was the same issue, so made this separate post. Link to comment Share on other sites More sharing options...
MarkMc Posted April 18, 2018 Share Posted April 18, 2018 Not the same as mine. Unchecking Recessed fixes that. Link to comment Share on other sites More sharing options...
Christina_Girerd Posted April 18, 2018 Author Share Posted April 18, 2018 Thanks for the tip. I unchecked recessed for all of them and then it mulled fine. Link to comment Share on other sites More sharing options...
pintodesign Posted April 19, 2018 Share Posted April 19, 2018 Just don't try to mull those together if you have lintels. Try it and see what happens. Link to comment Share on other sites More sharing options...
diSign Posted September 26, 2018 Share Posted September 26, 2018 sorry I have the same problem. Tried unchecked the recessed for all them and it still doesn't fix the problem. Any suggestion to fix this or is this really a bug? Thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted September 26, 2018 Share Posted September 26, 2018 9 hours ago, diSign said: sorry I have the same problem. Tried unchecked the recessed for all them and it still doesn't fix the problem. Any suggestion to fix this or is this really a bug? Thanks No the same issue probably so Post/attach a copy of your plan file to a Post so people can look at it for you. Make sure the Plan is closed in Chief when you attach it in the reply window otherwise it won't attach properly. Also, it's good to have your Forum Signature filled in, especially with the Software Version, and of course a real Name is nice too .............. See mine below in Blue for how to do that. If you don't see my Signature then you have them turned off for the Forum so you need to Toggle it on by going to the Upper RH Corner of this Forum Window and Clicking on your Username and making sure Signature are enabled (green) and then Add your Own Sig. too : UserName> Account > Signatures M. Link to comment Share on other sites More sharing options...
