1st floor ceiling heights won't change
Member Statistics
Similar Content
By mborean
Happy quarantine everybody!
I know it is there some where, but can't find how to change the ceiling heights for all the rooms on a floor at once. Working on a project an the client removed a bearing wall on the first floor, which changed the second floor framing from 11 7/8" to 14". This messed up the first floor ceiling height. To correct this, I had to go into each room on the second floor and edit the ceiling height above absolute. I am confident there is an easier way, but searched for 15min (I know short attention span) and couldn't find the answer.
Hope everyone is and stays healthy,
Mike
By kgcvt453
I am working on a living room/kitchen where I have added a cathedral ceiling and exposed beams. I wanted to make the walls higher since the beams can't go above the wall height. After I adjusted my walls to 12' the molding stayed at the default wall height. How can I move the molding to match the new wall height?
By Designer100
Attached is plan I am having issues with.an existing building I am designing beauty saloon . removiing exising dropped 10' ht. ceiling and
adding new celing at 12 ft ht wit 2x12 jsts at 16" o.c. spanning 20 ft 2" and resting on a 2x12 ledger bm (top at 12 ft) then gyp bd covering it continuous on each side of lease spacd.
15 ft off floor to btm of exist 6"x24in steel beams at 60" o.c. goint front to back of lease space. with 12" steel bar joists going side to side on top of them. then built up roof.
You can see the cross sedtion is not right. I put dimensions whter things is surpose to be. You can see camera of one space is not showing ceiling at 12' ht.
Thanks if you can assists.
PhotoReadyLease.zip
Prelim. Floor plan 04.17.2017.pdf
