boxerprod Posted April 11, 2018 Share Posted April 11, 2018 Hi everybody. That's me again I'm trying to achieve this kind of traditional roof structure. having reduced trusses with beam sitting on it and then rafters. (hope you will understand what i mean ) . I attach a picture of something very similar. I'm sure people have asked before but i couldn't find it in the forum. Maybe I searched for wrong terms. Hope you will be able to help me achieve this. thank you all Link to comment Share on other sites More sharing options...
Chopsaw Posted April 11, 2018 Share Posted April 11, 2018 Your Reduced Gable truss will likely have to be manually drawn with p-solids in elevation view, that can be converted to solids and exploded if necessary for material application for 3D rendering of wood grain patterns, or just left as p-solids for Construction Drawings. The beams sitting on the rafters at mid span will need to be p-solids or you can edit a lookout to fill that purpose in a roof layer set to opening no material or insulation air gap. Auto Roof framing should give you the rafters you need. Have a go at it and post your plan file if you get stuck. Link to comment Share on other sites More sharing options...
RL-inc Posted April 12, 2018 Share Posted April 12, 2018 The timber truss out of P-lines is how I have dine in the past. See attached symbols for examples 10-12TT.calibz CURVED TT 10-12.calibz 1 Link to comment Share on other sites More sharing options...
DavidJPotter Posted April 12, 2018 Share Posted April 12, 2018 Thanks Rob! DJP Link to comment Share on other sites More sharing options...
boxerprod Posted April 12, 2018 Author Share Posted April 12, 2018 Thank you , that seems the way to do it So i have to train thank you again to all of you. Link to comment Share on other sites More sharing options...
