Traditional "French" roof structure
boxerprod
Hi everybody.
That's me again :D:D
I'm trying to achieve this kind of traditional roof structure.
having reduced trusses with beam sitting on it and then rafters. (hope you will understand what i mean ) .
I attach a picture of something very similar.
I'm sure people have asked before but i couldn't find it in the forum. Maybe I searched for wrong terms.
Hope you will be able to help me achieve this.
thank you all
Your Reduced Gable truss will likely have to be manually drawn with p-solids in elevation view, that can be converted to solids and exploded if necessary for material application for 3D rendering of wood grain patterns, or just left as p-solids for Construction Drawings.  The beams sitting on the rafters at mid span will need to be p-solids or you can edit a lookout to fill that purpose in a roof layer set to opening no material or insulation air gap. Auto Roof framing should give you the rafters you need.
Have a go at it and post your plan file if you get stuck.:)
    32639
    DonahueC
    DonahueC
