3D Symbol Placement Block
lbuttery
I prefer to have a separate plan for each building then create a 3D symbol of each building and store in the library
then create a site plan with the terrain and roads and sidewalks and then place each building symbol in the site plan
as has been noted if the building needs changes then a new symbol has to be created and the placed in the site plan
I'm seeking an easy way to place the new symbol in its proper location
I'm trying to use a "placement block" sized such that the building needs to fit within the blocks "envelope"
I have the placement block as a polyline solid and set to red in plan mode
I currently have the "Sawmill_Symbol" layer off - turn that layer on to see how the Sawmill fits within the "placement block" envelope
I would like the "placement block" to be somewhat transparent so you can see the block and yet still readily see the Sawmill inside
I have fussed with the transparency slider but to no joy
I have forgotten how to adjust materials etc
any pointers on where I go to do this adjustment - there are so many dbx's and so many settings that I am lost
I don't understand why the transparency slider is having zero effect ?
also, try moving the Sawmill Symbol away from the placement block and then placing it properly within again
any tips on how to ensure accurate placement - hopefully "easily" ?
thanks for any tips
Lew
BUTTERY_SAWMILL_CT_SITE_180210_1120_LBX9.zip
Michael:
with the fill style set to solid the "transparency pattern background" is "grayed out"
Hence I didn't try the transparency slider (I should have tried)
I had set the "Fill Style" to sand and tried the transparency slider in 3D mode and nothing happened
I just tried it with fill style "solid"
I now see that it changes the transparency in plan mode
 I do like it at 50% transparency in plan mode
is it possible to control the transparency in 3D mode ?
that was my goal  - to see the Sawmill with the "placement block" in transparent mode
thanks
Lew
Michael:
thanks so very much for the refresher on setting materials and transparency
I now have the "placement block" set to transparency in plan mode and 3D mode
your tip on using "replace from library" works very nicely
so I suspect the "placement block" may not be needed anymore :)
open the attached site plan and in 3D mode turn off the "placement block" layer
then select the "Sawmill Symbol" and use "replace from library" and choose the TEST sawmill symbol
you should see one wall turn to blue paneling :)
in the past there has been debate over the "hassle" of keeping each building in a separate plan
and then creating them as symbols to be placed in the master site plan
"replace from library" appears to have eliminated this hassle :)
fantastic :)
Lew
BUTTERY_SAWMILL_CT_SITE_180211_0950_LBX9.zip
