Dgndssn Posted February 6, 2018 Share Posted February 6, 2018 Hello, trying to Make both roofs on plan a " Gable End" when I rebuild roof, I keep getting a "Hip roof" on left end. Also, see picture. Is there a way to build a parapit wall on one one of the house? Thanks, Doug Cabin 3a.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 6, 2018 Share Posted February 6, 2018 See if this helps you with regard to the gable vs. hip problem... Don't have time to get into the parapet wall thing right now but yes, that is totally doable by manually reshaping the wall polyline, by using roof planes to automatically cut the wall polyline, by using polyline solids, or by using primitives among other things. Link to comment Share on other sites More sharing options...
justmejerry Posted February 6, 2018 Share Posted February 6, 2018 Like Michael said in his video for your roof problem. Check this thread out for your parapet wall on gables. https://chieftalk.chiefarchitect.com/topic/16593-struggling-with-parapet-gable-walls/#comment-139620 Link to comment Share on other sites More sharing options...
Kbird1 Posted February 7, 2018 Share Posted February 7, 2018 Hi Doug..... The House End with the Hip Roof is no longer over its foundation (makes Gable wall mis-saligned too) and many of the Walls are marked as "Attic" even on the Main Floor eg the Hip Roof End The Walls with Roofs butting into them are not marked on the Roof Tab to be an Interior type if Roof is Split by Butting Roof and some need reversing to align below properly ie Stucco to exterior side. Delete All Roof Base Line and let Auto Roof do it's thing , this is a simple Roof , and it should build the Gable end all by itself. To add the Parapet add a BLANK Second Floor To add the Parapet add a Second Floor and select Make Blank Plan from Level 1 and accept defaults , ie hit Ok Then in Plan View on the 1st floor pull the two Roof planes back about 30" so they are no longer over the exterior Gable Wall Go upto the 2nd floor and Draw an Exterior Wall ( change your default exterior Wall to Stucco 6 1st) then draw a new wall directly over the Gable end wall ( hit F9 for reference Layer (Red) if needed ) In an Exterior View or Section View (maybe easier and more accurate) pull the new Wall down to the Desired Height after selecting it Use a Polyline Solid to Make a Cap for the New Parapet Wall (4 x16" Concrete seen below) Done No need to add Skirt Roof Over Door on Gable End if not Desired (ie. old Western Store "look" ) M. Also, it's good to have your Forum Signature filled in please, especially with the Software Version, and hardware can help too see mine below in Blue for how to do that. 1 Link to comment Share on other sites More sharing options...
Dgndssn Posted February 7, 2018 Author Share Posted February 7, 2018 15 hours ago, Dgndssn said: Hello, trying to Make both roofs on plan a " Gable End" when I rebuild roof, I keep getting a "Hip roof" on left end. Also, see picture. Is there a way to build a parapit wall on one one of the house? Thanks, Doug Cabin 3a.plan Thank you everyone, great help. Many thanks. Doug Link to comment Share on other sites More sharing options...
