CBRF23
Struggling with parapet gable walls
I'm getting beat-up by Chief pretty good this weekend.  I've been fighting with these parapet gables since Friday, figured I would get it sorted over the weekend but I'm having lots of trouble and figure it's time to ask for help
I got the rough form down, but trying to iron it all out is killing me.  Whenever I make an adjustment or move a wall, other unrelated walls move and change shape.
I'm also not sure how to get the lower floor walls to do what I want, which is to have a 2" brick return (photoshopped image attached).
I've attached the plan, and would greatly appreciate any advice here.  I'm willing to change tactics if anyone has a better way of making these.
The process I followed to create the parapets was 1) move roof up in Z 2) change attic walls to regular walls and modify an edge to get it to retain changes 3) move roof back down 4) drag roof planes back and snap to the inside edges of walls.
Parapets.zip
Any images of the actual house?
You want the end walls to extend 2" proud of the siding walls?
I use a ceiling plane to define the top of the parapet. And I added a solid to extend the wall proud.
I'm going for something like the attached image.
Would you be able to post back the plan you fixed up?  I'd like to take a look at how you did the ceiling plan.
Thanks!
Here is a simpler plan. Used a short wall to extend the brick wall. Note it's reversed so chief thinks it is a different wall type and will not merge them.
Ceiling planes draw just like roof planes. Come in at the same angle etc.
Easy to make look good in standard render, extra lines in vector, but not bad with the brick.
pg 1.zip
Solver, I opened up your plan, and that wall return is perfect. Eactly what I was going for, I'll have to incorporate your technique into my plan.
Did you happen to notice any issues with the gable wall resolving improperly?
When I opened your file I noticed the wall was improperly "skewed" on one side.  That is one of the things that's been happening to me and it's driving me insane - I get the wall set the way I like it (making sure to drag one of the corners so it doesn't reshape with the roof) and then after I change something else (i.e wall on other side of roof) it seems to reshape itself just like yours did, giving me an unevenly distributed parapet.
Check the attached screenshot, let me know if you've seen this on your end or not.
I left the right side "raw". Select the attic wall and drag it down to just below the ceiling plane.
    28589
    555555
    555555
  • Similar Content
    • By stanlee92218
      Let me start off by saying I am NOT an architect of any sort. My husband and I are building a house and I keep changing the floor plans. I cannot visualize anything on paper and we don't have anyone in our area that does these 3D renderings. I downloaded the trial to give it a shot myself and play around with changes before sending them to our architect. I watched a webinar the other week and I have watched video after video. However, I still cannot get the roof as I need it. I can't get it all connecting with the gable ends on the left and right ends of the house. I haven't been able to figure out how to add the additional window on the 2nd floor in the middle of the house. I know this is a rough sketch and its not all exactly the way our floor plans are, I am just trying to figure out how to get the exterior (mainly the roof) to work out as I have so far had good luck with all of the interior work. Any help and tips are greatly appreciated.
      on our main floor, we have 9' ceilings, cathedral ceiling in the great room that is open above, and 8' ceilings upstairs.
    • By OnlineBuilder
      Does anyone know how to draw these parapet eaves? They are not common here and I've only seen them used in one estate. If anyone has a cross-section drafted drawing of them, I'd love to have a look. Do they use a box gutter (big No-No in this area)?
      If I use a soffit block, for some reason they don't touch and half the soffit block disappears. I've noticed this with using them as posts. If anyone can explain this, let me know.
    • By Muhammad_Habib
      Hi there.
      I tried much, couldn't find any method in Chief to make Fences over Railings, which is required in many real world cases.
      I am not talking about Terrain Wall fences; rather, upper floors.
      Any idea?
      Regards.
    • By Boxon1
      Hi everybody,
      I am afraid that this topic was mentioned several times, but never really answered.
      I am working on house in Tucson, and this detail is killing me. It look like some kind of energy heel, but it's not. And I need these vertical ending web (stud, post, whatever) to attach other wall layers, and create a parapet wall.
      Perfect truss for this is made by company from Sierra Vista, AZ,  "Southwest Home and Hearth", http://www.southwesthomeandhearth.com/swt/trusstypes.htm, and they will probably be the chosen manufacturer, but I need to make this, because I need these trusses for interior (will be visible).
      I tried all kinds of truss settings, to make it look like shown on image  "Sloping-flat...jpg", but it just ignores me. And I don't have a clue in what direction should I go.
      This is definitely possible, because entire list of trusses on that web page was made in Chief, but how did they do it?
      How can I make truss like this?
    • By remis12
      Hello. I have sloped roof and I need parapet wall above roof sheathing. I draw how it should be. Any ideas?
