Kbird1 Posted January 21, 2018 Share Posted January 21, 2018 The Help Menu App that pops up allows its own Font etc to be adjusted but can the actual Help File Text Size be altered ? ie made larger , Size 12 , it appears to be Size 8 currently. I know I can zoom in on it but that causes you to have to scroll back and forwards or make the Window wider , so I'm hoping I've missed something..... M. Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 21, 2018 Share Posted January 21, 2018 The help files are in PDF format and as such can be made larger in a full-featured PDF reader. I think you have answered your own question above. How should Chief Inc know ahead of time, what your monitor resolution and settings are? A bit unreasonable if you ask me. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted January 21, 2018 Author Share Posted January 21, 2018 I meant the Built in Help Menu ( F1 or Help buttons in Program) not the PDF's which I also have and usually use cos, the Text is too small in the Help file , But because I think the Text in the Help Menu (vs PDF) is crisper than the low res. PDF version, I was hoping it worked like Word / Wordpad and simply made it fit the same space size by adding extra Pages at larger text sizes. M. Link to comment Share on other sites More sharing options...
MarkMc Posted January 21, 2018 Share Posted January 21, 2018 Could of things I found https://geekycoder.wordpress.com/2010/01/12/solutions-to-enlarge-the-text-size-of-chm-without-tears/ https://www.ghacks.net/2017/04/12/system-font-changer-restore-font-changing-in-windows-10-creators-update/ https://www.ghacks.net/2017/04/12/system-font-changer-restore-font-changing-in-windows-10-creators-update/ FWIW I use a download of the PDF and haven't noticed an issue with readability Link to comment Share on other sites More sharing options...
Kbird1 Posted January 21, 2018 Author Share Posted January 21, 2018 6 hours ago, MarkMc said: Could of things I found https://geekycoder.wordpress.com/2010/01/12/solutions-to-enlarge-the-text-size-of-chm-without-tears/ Hey thanks Mark , I will look into it since it seems 8 point is the default .... My windows Fonts are Fine I just use a .reg file from Ten Forums to set Menus, Icons etc to 12pt when needed , since M$ in their "Wisdom" removed the easy Win7 way to do it in Win10 FCU https://www.tenforums.com/tutorials/70839-change-menus-text-size-windows-10-a.html https://www.tenforums.com/tutorials/19768-change-icons-text-size-windows-10-a.html The Other reason for trying the Help File was that in the Past I have found that many of the Links in the PDF to other Pages don't work properly. M. Link to comment Share on other sites More sharing options...
MarkMc Posted January 22, 2018 Share Posted January 22, 2018 1 hour ago, Kbird1 said: Hey thanks Mark , I will look into it since it seems 8 point is the defaul I checked into this myself since I hit F1 so often. Chief help is not a CFM file so some of those solutions don't work. Can change the entire system to 125% but that isn't so good. I downloaded Advanced System Font Changer. Haven't given it a go yet though, bit much going on for that (in the course of things I did find a way to load the Group Policy Editor onto my Spectre which has Win Home-hope that works, will save me the cost of an upgrade Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2018 Author Share Posted January 22, 2018 16 minutes ago, MarkMc said: I checked into this myself since I hit F1 so often. Chief help is not a CFM file so some of those solutions don't work. Can change the entire system to 125% but that isn't so good. I downloaded Advanced System Font Changer. Haven't given it a go yet though, bit much going on for that (in the course of things I did find a way to load the Group Policy Editor onto my Spectre which has Win Home-hope that works, will save me the cost of an upgrade Actually I just got the Advanced System Font Changer too as it lets you adjust scrollbars and Icon spacings (desktop) etc too, works well so far , it pulls up the Old windows style Icon and Text sizing boxes in some cases , you then need to log out or do a restart to set the new sizes. I recommend saving the defaults 1st time you start it too , and once you have it all as you like it, save the settings to file (.reg) so you can reset them simply by double clicking the .reg or importing back into ASFC and rebooting as Win10 Cumulative Updates have a habit of resetting this kind of thing I have found. I just put a Report into the Beta team about the Font size in the Help file , might help if you do as well ...assuming you want it too... I thought the help file was a .chm too , do you have more info on that , cos those other links didn't help me either....thanks Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2018 Author Share Posted January 22, 2018 yes it was a problem in X9 too for me , so figured I would ask and see if it was just me .... never heard of the QT Assistant before , so thanks , I did find the doc.qch file in the Manual folder but wasn't sure what they were. C:\Program Files\Chief Architect\Chief Architect Premier X10 (64 bit)\Manual\ I can change the QT Assistant Font but not the Help file itself's Font , which is what lead to all this.... I assumed it was a normal Help File... (.chm) Link to comment Share on other sites More sharing options...
MarkMc Posted January 22, 2018 Share Posted January 22, 2018 32 minutes ago, solver said: Help is based on QT Assistant. So I checked the documentation on QT Assistant- thanks Eric 15 minutes ago, Kbird1 said: I can change the QT Assistant Font but not the Help file itself's Font , which is what lead to all this. Option in View to Zoom in changes the size of the information window it appears that once zoomed in the size holds when closed and reopened, also holds after closing Chief and reopening. Edit/ Preferences only changes the size of the font in the bookmark/contents panel. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2018 Author Share Posted January 22, 2018 13 minutes ago, MarkMc said: So I checked the documentation on QT Assistant- thanks Eric Option in View to Zoom in changes the size of the information window it appears that once zoomed in the size holds when closed and reopened, also holds after closing Chief and reopening Edit/ Preferences only changes the size of the font in the bookmark/contents panel. Thanks Mark , I know you are just trying to help but I was aware of that , it's what started the question...ie all the scrolling around while zoomed in. I am guessing they restrict the font size to 8 point , to restrict the size of the Download ( smaller file size) on each Upgrade ie saves them money.... there seems to be no way to change the Font once it is "complied" , at least not without expert help. re: the 1st post : I know I can zoom in on it but that causes you to have to scroll back and forwards or make the Window wider , so I'm hoping I've missed something..... Link to comment Share on other sites More sharing options...
MarkMc Posted January 22, 2018 Share Posted January 22, 2018 21 minutes ago, Kbird1 said: know I can zoom in on it but that causes you to have to scroll back and forwards or make the Window wider , so I'm hoping I've missed something..... That doesn't happen to me using the Help functions zoom. The text wraps. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2018 Author Share Posted January 22, 2018 19 minutes ago, MarkMc said: That doesn't happen to me using the Help functions zoom. The text wraps. Thanks , Are you in Full screen or ? I usually have it open on about 1/2 or 1/3 of a 1980 wide screen i use on the side for this and email etc , and found I was having to scroll left / right if zoomed in too far, I guess I need to play more with different settings maybe as that looks pretty big? and is wrapping to the Window properly. Did you reset the fonts in the browser? or the application? I have no idea what either is referring too , would you mind doing a screen grab for me thanks.... as they seem to reset the settings if you close it.... Is that Tahoma Font ? M. Link to comment Share on other sites More sharing options...
MarkMc Posted January 22, 2018 Share Posted January 22, 2018 8 minutes ago, Kbird1 said: Did you reset the fonts in the browser? or the application? I used View, Zoom within the help where circled on screenshot. I also change the size of the contents navigator-edit preferences, application. Screenshot here is full screen on the 13" Spectre. Text wraps, on this machine I shrank the navigator a little since not all illustrations shrink all the way to fit. Less of an issue when I first checked on the 17" Sager, at the office I have help open on a second of 3 screens Link to comment Share on other sites More sharing options...
Kbird1 Posted January 22, 2018 Author Share Posted January 22, 2018 I was playing with the Fonts in Edit>Preferences If I set it to Application and Custom Settings, it changes the Contents Pane , open pages and Menu Font text sizes etc, But I don't seem to have the same luck if I Set it to Browser ( which I assumed was the Help file html ) and try the same thing.... you can set it but nothing happens apparently I'll keep playing and see what happens , perhaps I messed a setting up playing with it last week? Link to comment Share on other sites More sharing options...
Kbird1 Posted January 23, 2018 Author Share Posted January 23, 2018 CA have let me know that at this point in time the Zoom Option is the only way to increase the Font size of the Help File and they have Logged Font Resizing as a Request with the Documentation team, so thanks for the Input and Help anyway Guys , but it is what it is for now...... KB Link to comment Share on other sites More sharing options...
