40mstew Posted January 16, 2018 Share Posted January 16, 2018 When I do a camera view, why doesn't the area I have highlighted in yellow show? What is it in the layer display options do I not have checked? Link to comment Share on other sites More sharing options...
justmejerry Posted January 16, 2018 Share Posted January 16, 2018 Looks like your framing floor joists layer isn't on. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 16, 2018 Share Posted January 16, 2018 you may need to Build the framing too if you haven't already and auto framing is off.... M. Link to comment Share on other sites More sharing options...
40mstew Posted January 16, 2018 Author Share Posted January 16, 2018 "All on set" is on. See pic. Still not showing. Any other thoughts? Link to comment Share on other sites More sharing options...
Kbird1 Posted January 16, 2018 Share Posted January 16, 2018 Check the ALDO and make sure that EVERY Layer has a blue Check mark under Display for the ALL ON Set......I am thinking at some point you have turned off Rim Joists for example , since I now see Joists. from what I can see in the pic your glass rail extends below the floor? M. Link to comment Share on other sites More sharing options...
40mstew Posted January 16, 2018 Author Share Posted January 16, 2018 I did notice that if I changed the wall from the glass wall to a regular wall it fixed the problem for that wall. The exterior wall however is still the same. Plan file is attached. Stewart_2018_1-16-18.plan.zip Link to comment Share on other sites More sharing options...
Kbird1 Posted January 16, 2018 Share Posted January 16, 2018 when was the last time you built the Roof in this plan ? It 's easier if you save the camera in the location you want people to look at ,so they can just open the saved camera. also you have not done your Signature...so people don't know what version you are using and both x9 and x10 are now active......see my signature to do yours... Your glass rail is setup incorrectly , use panel style and set the panel as glass.....you also set the interior and exterior wall to glass ...should be drywall sso you don't see the framing Link to comment Share on other sites More sharing options...
40mstew Posted January 16, 2018 Author Share Posted January 16, 2018 X9. Played with the roof, will be doing a custom roof. don't like how chief builds the roof. Not sure what you mean by a signature. Will read up on the wall defs. Thanks. Link to comment Share on other sites More sharing options...
Kbird1 Posted January 16, 2018 Share Posted January 16, 2018 I edited above while you responded....... your glass rail is setup incorrectly .... you have the wall material set as Glass. see above edit: forgot to mention to rebuild the framing after you fix the Railing... Link to comment Share on other sites More sharing options...
40mstew Posted January 16, 2018 Author Share Posted January 16, 2018 Thanks Kbird1 and Solver. Will look into both. Thanks. Link to comment Share on other sites More sharing options...
Chrisb222 Posted January 16, 2018 Share Posted January 16, 2018 4 hours ago, 40mstew said: When I do a camera view, why doesn't the area I have highlighted in yellow show? What is it in the layer display options do I not have checked? Check your wall type definitions. Some of your exterior walls don't have an exterior layer. Such a wall will not cover the floor platform. Move "Stucco" layer up one, to the exterior layer: Link to comment Share on other sites More sharing options...
