natevermod Posted December 27, 2017 Share Posted December 27, 2017 I'm relatively new at Chief but have picked up on things fairly quickly. One problem that recently came up was small, blurry texts when I send a plan to layout and try to print. This hasn't happened in any other plans or layouts but randomly started today. I've tried changing settings, comparing settings to plans that weren't burry, and even taking a working plan and altering it. Any help would be greatly appreciated. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 27, 2017 Share Posted December 27, 2017 Such is commonly not Chief Architect oriented but rather video card centric. You might try a little larger or different font. You should make sure your video card software drivers are up to date. If this persists, I recommend that you contact Chief Architect Tech Support for advice. DJP Link to comment Share on other sites More sharing options...
Kbird1 Posted December 27, 2017 Share Posted December 27, 2017 Posting a "bad" plan and a "good" one may help someone pinpoint the issue for you, just make sure the Plan is closed when you attach it to the Forum Reply box in the light grey area or it won't let it attach since Chief locks the file while in use. Just blurry text in Layout ? Is this just in the Printed (PDF?) Output or on screen? Have you checked that you are sending to Layout on the Same Scale? ie 1/4=1ft are you using Layout Line Scaling ? PS . it's also a good idea on the Forum to fill in your Signature ( see mine for how) so People know who you are and what Version you are currently using. Link to comment Share on other sites More sharing options...
rlackore Posted December 27, 2017 Share Posted December 27, 2017 If you can't post the plan, at least post a screen shot or an image of the printed output. Link to comment Share on other sites More sharing options...
KirkClemons Posted January 1, 2018 Share Posted January 1, 2018 Try out different fonts as well. Barring that, make sure you are not sending the view to your layout as an image. Link to comment Share on other sites More sharing options...
