JAMESACLARK Posted December 19, 2017 Share Posted December 19, 2017 Hi Folks, I have been sending elevations to layout recently using the plot lines with color fill box checked for the past few months quite successfully, and then today I experienced what I thought was double vision, but actually what I realized i that the image doubled itself. one version is the outlines of the drawing and the double and the other is the colour infill slightly skewed to the left. 19 12 17 65 Clinton Presentation layout legal size.pdf Just last week i did one for another project and worked just fine...December 7 2017 36 Deerford East Wall Kitchen Elevation with Exhaust Hood.pdf anyone know what is going on here? for now I've gone back to using live views. I stopped doing that a while ago because my DH (the designer) hates seeing the blurry elevation in the live view. ( I realize that it becomes clear when we print it, but it irritates him to see it when we are arranging the layouts) Link to comment Share on other sites More sharing options...
rlackore Posted December 20, 2017 Share Posted December 20, 2017 This is a known issue - many previous posts about this behavior. Link to comment Share on other sites More sharing options...
DavidJPotter Posted December 20, 2017 Share Posted December 20, 2017 I only do black and white elevations and wall elevations using "plot Lines" so I have not seen this as I do not use color at all except for standard and ray-traced renderings. DJP 1 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted December 20, 2017 Share Posted December 20, 2017 19 hours ago, JAMESACLARK said: anyone know what is going on here? James your example is a little worse than the current capabilities of the software however you still have offset in your good example and you should send in both to tech support and if they hear from enough people it will eventually get fixed. 1 Link to comment Share on other sites More sharing options...
