Joe_Carrick
Forcing a redisplay?
The F5 key forces a redisplay.  Is there any way to cause that to happen automatically from within a user macro?
If not it would be really nice if CA would add 'F5' as a Global Special Character.
This sounds like a nice idea on the surface Joe, but even if we could do that with a macro, the macro wouldn't execute till that screen redraw so we would be right back at square one.
So, if there was a <F5> special key that could be placed in a Label wouldn't that force the redraw?
No...because the macro would never be executed without the redraw to start with.
Quote
So every time the label was drawn, it would execute the macro which would then force a redraw which would draw the label again.  This is what we call an endless loop.
I'm not sure what problem you are trying to solve but I don't think this is the solution you want.
Dermot, here's the situation I'm trying to solve.
  •  Macro_1 sets a $Global variable.  $LayerSet  (get's the layer_set_name from a text object - generally the view name text)
  •  $LayerSet is used in other macros to control the result.
  •  Macro_1 may not have executed before the other macros so $LayerSet might not be correct if I've just switched from a Plan view to an Elevation view.
  •  <F5> or pan/zoom is currently the only way to force the redisplay
The layer_set_name attribute is only reliable for CAD objects in any view other than a Plan View.  It's not reliable in Camera Views (Elevations, Sections or Interior Elevations).
Maybe that just needs to be fixed.  Then I could just use the object's layer_set_name from within the Label macro.
I agree with the problem and is a good argument against using Macros. The problem has been around since X3 and is basically because it is impossible the control or know the order of the object updates. The order will always change with every insert/delete.
A easy solution, which i also sent in, is to add a feature to define within a macro, modes of which that macro will  executed -- as in: start of update, with object update, at end of update and opening/closing plan only. This again might force the re-execution of some objects which would than be made without macro execution-- which chief does a lot of right now. There is little chance of Chief doing anything -- IMNOHO.
    27478
    Oilersfan20
    Oilersfan20
