Moving Walls - Framing Does Not Move
tswitos
I modeled a small 20x10 ICF building and auto framed the floor joist and ceiling beams.  I changed one of the walls to 15'-10", but the framing did not update to the new length.  Is there a way to make sure the framing updates if wall lengths are changed?  Thanks in advance.
There is a setting that you have to check . Look threw the defaults under build . I have had issues finding certain defaults as i use the program . It is best to change all these defaults prior to doing some designs & setting up a template of the way you want the program to work
Okay.  I will try that, because I don't think I had that checked.  I didn't have that checked, because I don't have any framing in my walls yet.  I only have exterior ICF walls (concrete). So I'm just interested in the foundation and ceiling framing.  Thanks.
