MosbyBA Posted February 28, 2014 Share Posted February 28, 2014 Hello Everyone, I will try to keep this as simple as possible. Here is what I see: Notice the connect walls icon is floating next to the cursor, and the circles are on the ends of that wall type, this wall is in our legend. The circles do not display when sent to layout, but they are only there in the plans. The join walls icon follows the cursor around and is very annoying. This is in a newly upgraded version of X6 premier. The wall was built properly, I checked that a few times. Any idea on what might be causing this display? Link to comment Share on other sites More sharing options...
Dan_Park Posted February 28, 2014 Share Posted February 28, 2014 Chief is being "helpful" by circling walls where it believes they are close enough to be connected. It's actually a good feature in most cases because if you have disconnected walls they can cause some very hard to track down problems. I suspect if you put a little more space between the two middle walls it might clean-up. 2 Link to comment Share on other sites More sharing options...
MosbyBA Posted February 28, 2014 Author Share Posted February 28, 2014 HA! Well that was it! I have never seen that before, I scooted the walls down a little away it all went. Thanks for the help, Im coming up on using this software professionally for a year now, so Im still trying to come to grips with some of its quirks, after using Autodesk products for almost 12 years. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted February 28, 2014 Share Posted February 28, 2014 If what Dan doesn't work for you just build the walls in CAD with fill. I know it's a pain, but then so are the circles when you can't get rid of them. Link to comment Share on other sites More sharing options...
Go-Bears Posted February 28, 2014 Share Posted February 28, 2014 Is there a way to turn off this feature for a specific wall connection? I have a case where I am putting a very custom railing next to the intersection of an invisible wall and framed wall. It is where I want it to be but Chief helpfully keeps pointing out that it is not connected. As said above the curser symbol is annoying. Maybe a better way would be to designate a wall as not connected regardless of position. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 28, 2014 Share Posted February 28, 2014 You can try to make the railing wall a "no room definition" wall, then you can slide it into the invisible wall if I understand you correctly Link to comment Share on other sites More sharing options...
Go-Bears Posted February 28, 2014 Share Posted February 28, 2014 Thanks you would think that by now I would have looked at that. 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted February 28, 2014 Share Posted February 28, 2014 Just trying to help, I heave no idea what skill level you have. Link to comment Share on other sites More sharing options...
