Nailerman19 Posted December 6, 2017 Share Posted December 6, 2017 Is there a way to use a door slab only without the jamb etc? In this particular situation we'd like to use a wide door slab as a narrow partition between a vanity and the toilet to provide a bit of privacy. Thanks. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 6, 2017 Share Posted December 6, 2017 A door slab is just a polyline solid so it would be easier to just use a polyline solid for your partition or possibly a thin railing wall would also work. Link to comment Share on other sites More sharing options...
Kbird1 Posted December 6, 2017 Share Posted December 6, 2017 A Partition or Soffit from the Cabinet Tools will do that for you better as a Door will need a Wall etc to place it..... Link to comment Share on other sites More sharing options...
Nailerman19 Posted December 6, 2017 Author Share Posted December 6, 2017 Thanks for the replies. I should have clarified that we'd like to use a three panel door to add some interest with the upper panel being a decorative glass to allow some light through. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 6, 2017 Share Posted December 6, 2017 So then open a new plan and insert your chosen door into a short wall and then change the wall to a room divider and remove all the stuff on the door that you don't want. Then create a symbol and use that in your bathroom. I have a tutorial with a few more details that might help as some of the procedure will be the same. Link to comment Share on other sites More sharing options...
rlackore Posted December 6, 2017 Share Posted December 6, 2017 Okay, Chopsaw beat me. But anyway, here's a simple step-by-step: 1. Start a blank plan. 2. Draw an Interior Wall. 3. Insert the door you want, size it appropriately. Then open the door dialog box and uncheck Casing>Use Interior Casing; also set Hardware>Handles/Locks to None and Hardware>Hinges to Hidden. 4. Shoot an ortho view and remove the wall with the 3D>Delete Surface tool. 5. Now you have a door with nothing you don't need. Make it a Symbol with Tools>Symbol>Convert to Symbol. I typically define this kind of thing as a Millwork symbol. 6. Insert into your plan. Link to comment Share on other sites More sharing options...
Nailerman19 Posted December 6, 2017 Author Share Posted December 6, 2017 Thanks rlackore and Chopsaw. That procedure worked great Link to comment Share on other sites More sharing options...
