Sign in to follow this
D11-Design
Ray Trace - Glowing edges
Dear All,
This is a 50 pass render with only sunlight turned on. Ambient occlusion: min. 0.1 max. 2.0.
My problem is obvious: the glowing edges at the northern part of the image. Have tried adding a foundation + roof, no success.
Any ideas? Will try to solve the issue with Affinity Photo, but it would be much more efficient if raw ray traces looked OK. I have seen ray trace images with sunlight with no glowing edges so there must be some solution (the issue only occurs when sunlight is on).
The side of the hood also doesn't look quite client-friendly. Someone suggested adding spot lights, is that the only way to fix it?
Any help would be greatly appreciated!
Kind regards,
Gabor
Have you tried building a roof and foundation?
You could also post your plan so we could give it a try.
Hi rispgiu,
Please find attached the plan.
Have tried to build roof/foundation but it didn't help.
But you can try, I might have done something wrong.
Your help is much appreciated!
Gabor
Csoport_2B.plan.zip
Even with a roof and foundation, if you have the sun intensity and/or the environment light cranked up too high you will get that light bleed.
Just took a quick look at your plan. The roof could be a problem as there are no overhangs on several of the sides, try building this again. With the foundation it needs to have a floor, the foundation you have seems to be just a slab type. You may need to change this so you can assign an actual floor to it.
Graham is way more knowledgable that I at this, as matter of fact I am trying to learn from his work. I agree with him, I looked at your plan and after rebuilding the roof and the foundation I ran a quick RT and I did not get the same light issue as you did.
Unfortunately I'm on a timeline and I need to run a RT for a project of mine and I could not finish rendering yours.
Also I ran mine with uniform intensity at 1.5 and I unchecked the use camera view settings.
I hope this helps
Hi rispgiu,
Could you please put the modified plan here.
I have added the roof but it does not show in the camera view inside the room (outside the roof is visible). Could that be a problem?
I have tried the plan in the Let's ray trace thread and it worked. When I removed the roof, there was light bleed, when I added the roof, it was gone (!). The only difference I noticed is that the edge of the roof is visible inside.
So I am still not able to fix the issue in my plan.
Do you have Premier? I have Interiors, I believe that can be the issue. Whatever I place outside the room (house) it is not visible through the window.
However, in the plan from the Let's ray trace thread I can place objects outside and they are visible (perhaps that plan was made with Premier?). So because the roof in my plan is not visible inside, it means it is not taken into consideration during Ray Tracing?
Or any other idea?
In photography I would say you were "blowing the highlights"   you are way too bright and your intensity level is way high too.
Contrast is 100% cos you left it on Auto etc under Tone Mapping
Rebuild the Roof on Auto , you have tried adjusting the planes,  as this works for me.... I don't have all your textures like on the ottoman etc. so 50 passes only took 1.22 Minutes , (1280 x720)  my usual 10 passes took 17 secs ...maybe the fastest I have seen , no textures helps apparently :)
Take a look at these Settings for a Starter , hopefully you have X9? , you have not filled in your signature so people know your specs....see mine below for a how too...
Csoport_2B.plan.zip
I thought you had set the Windows to Opaque glass ? but didn't check, I know Interiors can't generate a Sky ( I don't use it much anyway) but I had assumed you still had Backdrops ?
I can turn it on in your plan but I have Premier. Interiors can't do Terrain etc either which maybe why they don't let you place objects outside.
3D>3D view defaults>Backdrop
you may want to look at what you can and can't do in Interiors....
https://cloud.chiefarchitect.com/1/pdf/marketing/x9feature-matrix.pdf
1 hour ago, D11-Design said:
Hi rispgiu,
Hello, I didn't have all of the textures you did but here is the file with roof and foundation. The file that Mick provided you with might be better than mine, you may want to try that one first. Please let me know if there is anything else I can do to help.
Csoport_2B.G-R.plan.zip
the biggest issue is the Tone Mapping Settings ...just way to bright.... I set set it up something close to Graham's Post here ....
Tone Mapping "ON"
Contrast 35%
Intensity 35%
Softness 4%
Color Correction 0%
Brightness 48%
Contrast 70%
Saturation 50%
https://chieftalk.chiefarchitect.com/topic/14512-lets-ray-trace/?do=findComment&comment=123490
Please note I always do my ray traces with photon mapping turned ON as it looks much more realistic to me.
I am now starting to believe the issue could be fixed by upgrading to Premier (which ray traces outside objects, such as the roof as well). So the roof would put shadows in the way of sunlight, not like now when the roof is not visible which I think means the roof is not there when ray tracing.
Alternatively, I am curious about the upcoming X10 (because this light bleeding is clearly a rendering bug in X9, let's hope it will be sorted out in X10). Someone mentioned a new function called physical rendering. Do you know anything about that? Or when X10 will be out?
You can get a hint about PB Rendering in the X10 Preview Video, but it's public release is 4-6mths away I'd think , usually comes in the 1st or 2nd quarter of each year and as long as you have current SSA you get the upgrade free , so no reason not to go full version now , there is an option to Rent Premier too.
Yes Photons on in all above pics but Caustics Off as they increase the time factor ......
Send your Plan to TS and get a few answers , as I see no reason Interiors shouldn't be able to do a good RT of an Interior, The Bleed is a known problem with the RT engine if there is no Roof or Floor system/foundation , not sure it classifies as a Bug though since the light needs something to bounce off and contain it...
Gentlemen,
look at this:
I have figured out the solution. I need to build a roof when a new plan is started.
When I added the roof in the existing, furnished plan it was not visible in the camera views and therefore, it was not ray traced.
I had to start a new plan, draw the walls again and copy all the furnishing. When I copied the camera from the original plan, the roof was still not visible! However, when I placed a new camera in the new plan, the roof was there and the ray trace is finally OK...
Thanks for all your help!
Glad you were able to get the roof working. Just wondering if the reason was related to your camera display settings, check the original plan to see if all of the roof elements were turned on, especially the roof planes.
Didnt think about it earlier but I just looked in the Original Plan and the Camera (no3)  is a FLOOR camera not a FULL Camera ....hence no roof or foundation
    28631
    sawallace64
    sawallace64
  • Similar Content
    • By pgjacob
      HI All
      I am ray tracing a scene with a 3D plant (from sketchup) and the shadows are showing squares rather than the actual shadow of the plant (1 pass image shown below).  I have purposely moved the sun around to cast shadows to the back of the image as I have found manually manipulating the sun gives much better RTs than using natural sun angles (at least for me).  I attach the skp file and what the plant looks like in the object info window of CA.  Any ideas how to get rid of this square shadow?  I uncheck the ray casted shadows in camera tool pre-ray trace, and it looks better but still ray traces with the square shadow.
      Thanks in advance,
      melissa
      Blue Flax Lily.skp
    • By hamedDesighn
      Hi every one , how can i achieve these as shown in pictures below with raytracer render  :
      Guys im really waiting for someone answering me please
    • By No1ZZTopfan
      Instead of spending hours searching, I prefer to do this. My apologizes.
      I've designed homes in previous versions of CA. All the way back to 4. Well, computer HD crashed a while back and nearly lost everything. After new HD, installation of CA 12 w/bonus materials, its back to normal. However...
      When I render anything in any of the 6 houses in version 12 I get this alert window (see pic) telling me it can't find the files on the list. Instead of spending hours replacing each one, I would like to know if there is way to simple delete or restore them back to their default material setting, delete them altogether, anything! I can't seem to do them (delete is dimmed) either for some reason. Thanks in advance.
      Using CA 12 with all bonus materials.
