Phantom cabinet
Nancy1431
Either use a back clipped section OR change the wall the cabinet to no room definition (then the perpendicular wall doesn't show without a kludge (included) OR make the cabinet in the closet in two pieces- one that is in front of the wall and the other inside OR make that wall/opening out of psolids.
Second option included here. FWIW 30" deep is kinda cumbersome at that width cabinet.
Plan_fix.plan
8 hours ago, Kbird1 said:
I have not had this issue with a Wall elevation , they usually work well.
I personally run into this type of thing all the time.  Sometimes its not being able to see the cabinets in an adjacent room, sometimes its because a particular view needs to span multiple rooms, sometimes its because I simply want to display objects in the background—the list goes on.
Anyway, here are a couple of screenshots and a quick example plan for the OP...
5a28ee1f7e4e2_Mask1.thumb.jpg.2d55538ab20839a4fddfa66c2d27de4f.jpg5a28ee1e8b18a_Mask2.thumb.jpg.93c223e4a55e2fbdeed001e84cc93e8f.jpg
CAD mask.plan
