Sign in to follow this
SNestor
Roof Overhang Extension - how to?
Wondering how to create a roof overhang extension...and control the overhang.  If I drag the roof 36" from the face of the wall just where the garage doors are...and make the overhang 36" deep...then, the upper roof also has a 36" soffit...which I don't want.
I tried to use a separate roof and made them coplanar...but, then I couldn't get a flat soffit.  Maybe I was doing something wrong.  This should be simple to accomplish...yes?
Here's a picture of what I'm trying to do....this pic is just an example.  I want to create a longer overhang segement above my garage doors with a flat soffit back to the wall.
Here is a pic of my plan...shows the roof extension with a 12" overhang.
Place a manual break or two in the roof plane and drag it out or use the temp dimensions and it should work fine.  Post the plan if you have any issues.
Its actually just a porch in Chief.  Id use a custom railing without the rail, make it a room.  When you make the roof plane just extend it over like your picture shows.
Thanks Johnny...the porch room idea did the trick.  Now...if I could only get all the trim to auto generate correctly.  It's always something.
Sample plan attached.
PORCH - ROOF EXT.plan
Good luck with that. I've found this to be somewhat buggy.
ct1.thumb.jpg.ac88d87b41b91e314f9c4db2084747bd.jpg5a10f63948d01_dce3.thumb.jpg.d1af5322f8bab1150667e8d6cd93f73e.jpg
3 minutes ago, Chopsaw said:
Is that the same plan Eric?
Of course :)
I auto built the roof, then added the missing molding manually.
Don't know what it's supposed to look like.
Ok that's cool, I guess Steve will have two options in the morning.  I don't get requests for Frieze boards often.;)
    27489
    ChiefRochelle
    ChiefRochelle
  • Similar Content
    • By 9atatimer
      I'm using X11 premier on a mac -- I have an exterior garage wall (with a centered garage door) and a gable end -- I'd like to split the attic wall of the gable end into 3 parts -- the central region above the garage door, and the left and right, to have a different material above the garage door.
      I have Default Settings > Roof > Auto Rebuild Roof set to Off
      I have Default Settings > Framing > Automatically Build Floor and Ceiling Framing Off on all framing types.
      I have Default Settings > Walls > General Walls > Auto Rebuild Attic Walls set to Off
      If I delete the roof and ceiling planes with Build > Roof > Delete [X] and then use the Build > Roof > Build Roof ... dialog to rebuild the roof and attic from scratch -- I leave the Auto Rebuild Roofs set to Off, to be clear -- and then edit the resulting gable roof on the attic layer, I can split it twice to produce the three separate wall sections, but once I change the exterior material on any of the sections, the three wall segments get replaced with a single wall again.  The new wall has my selected material, but that does me no good as I need the distinct secgments.
      Anyone know what setting do I need to turn off to maintain the manually edited gable end?  Or is this a mac bug?
      Or, barring that, does anyone know what approach will let me give the desired finish detail (attached a pic of a freehand elevation)?
    • By blueriver
      I'm using Chief Architect Premier X11
      I have all these little 'X's can someone please tell me how to get rid of them?  I've been really playing around with the roof and i THINK they are from that but at the same time i have a couple random ones outside where the roof is -- i cannot get them to go away. Help!
      thanks in advance
      Lauren
    • By chief69
      Hello, We are having a hard time getting  the design program to do the roof right. We have tried with Sketchup and it got the closest. It's hard to describe I have attached a few pics with a decent idea of what we are trying to do.
      The Garage is a shed roof as well as the breeze way, but they are at different angles. The house is a butterfly style with the V running at a angle. WE do not care what the pitch ends up being on any of the roofs.
      Anyone know how to do this. I have been trying for hours and the program goes crazy every time. Esp with the all 3 roofs at different angles with each other. I have attached a copy of the plan we made and some pics from sketchup because that program got the closest to what we are trying to do.
      Thanks
      Chris
      New house v1.plan
    • By MN_JohnH
      I wonder why my second floor loft flooring is sticking through the roof and can be seen on the outside of the building?
