Room Sch Ceiling Height?
ACADuser
The building has a 14' tall structural ceiling & metal framing at 8' in most rooms but not all.
I used the ceiling plane to get the 8' ceiling in a room but the Room Schedule still shows the higher ceiling.
What is the attribute I need to use for the drop ceiling in the Schedule?
Or do I need to use a different procedure for room ceilings?
Room schedules won't display the heights of any custom ceiling planes.  You can have any number of custom ceiling planes at various slopes that may cover any portion of a room and the room schedule is just not smart enough to determine which height(s) you want to display.
From what you have described, you might be better off using a shelf ceiling instead of a custom ceiling plane.  Shelf ceilings allow you to have an interior room with a lower ceiling and lower walls that are independent of the overall structure.  They will also display the correct ceiling height in the room schedule.
Hey, that's not a bad idea Dermot.
This method will only work for rooms within rooms though so here's what you'll have to do if your room isn't in another room...
  • If you don't already have one of these, create yourself a custom room divider wall type that has a single insulation air gap layer .01" thick.
  • Select the room you would like to have a dropped ceiling and make sure it is excluded from schedule (not necessary if you aren't using a schedule.
  • Draw some walls around the perimeter of your room using your custom room divider wall type until they form an enclosed room.
  • Drag those walls till they snap to your main walls.
  • Open your enclosed room, set the structure to have a shelf ceiling, and adjust the ceiling height and structure settings as desired.
Note that if you're using a room finish schedule with a wall finish material column you may need to create a special gap material with the same name as your main interior wall finish.
