raltd9245 Posted October 16, 2017 Share Posted October 16, 2017 I'm trying to find contemporay translucent glass o h garage doors. Anybode have one Link to comment Share on other sites More sharing options...
MarkMc Posted October 16, 2017 Share Posted October 16, 2017 Zipped plan used to make the one pictured. Used a wall cabinet, included panel for glass (though it's cherry when you look at it) used as side panel inset in cabinet. Open DBX to see cabinet structure. Adjust to what you need and convert to a symbol. Garage Door.zip 1 Link to comment Share on other sites More sharing options...
raltd9245 Posted October 17, 2017 Author Share Posted October 17, 2017 thanks much appreciated Link to comment Share on other sites More sharing options...
CJSpud Posted October 17, 2017 Share Posted October 17, 2017 You can probably get what you want from the library: Just copy/rename the glass material and edit the panel's properties as needed. All I did with this one is up the transparency. Mark's method gives you a lot of flexibility on the door design itself. I would find a manufacturer that makes what you need and then utilize whatever technique(s) to create a door that best resembles what will actually be purchased and installed. 1 Link to comment Share on other sites More sharing options...
dshall Posted October 17, 2017 Share Posted October 17, 2017 And here is a couple more... Contemp garage door dshd and mark.plan 1 Link to comment Share on other sites More sharing options...
