Cassidi Posted October 2, 2017 Share Posted October 2, 2017 Does anyone know how to adjust the height of a window lite in a Craftsman Style Window? Any help would help! Thanks dudes. Link to comment Share on other sites More sharing options...
Cassidi Posted October 2, 2017 Author Share Posted October 2, 2017 I can add more, but I want to make the lite 1/3 up the window, not right smack dab in the middle :/ Link to comment Share on other sites More sharing options...
Dermot Posted October 2, 2017 Share Posted October 2, 2017 You can change the number of vertical lites to adjust the height. If the number of vertical lites is 2, the height will be 1/2 the window height. If the number of vertical lites is 3, the height will be 1/3 the window height. If the number of vertical lites is 4, the height will be 1/4 the window height. etc. Link to comment Share on other sites More sharing options...
Chopsaw Posted October 2, 2017 Share Posted October 2, 2017 I think you are looking for the craftsman style with 3 Lites Vertical which is also very common with 3 or more Lites Across. Link to comment Share on other sites More sharing options...
glennw Posted October 2, 2017 Share Posted October 2, 2017 4 hours ago, Cassidi said: I can add more, but I want to make the lite 1/3 up the window, not right smack dab in the middle :/ Use Craftsman type in a Fixed window with 1 light across and 3 lights vertical. Or, if you want the choice of top third or bottom third (or anywhere really), use a Single Hung window and use the Bottom Component Size setting to place the muntin. Or, you can always use Custom Muntins. Link to comment Share on other sites More sharing options...
Cassidi Posted October 3, 2017 Author Share Posted October 3, 2017 Thank you guys!!! Link to comment Share on other sites More sharing options...
ChiefWorkhorse Posted December 19, 2017 Share Posted December 19, 2017 How do I move muntins freely. Is there a way like modifying cabinets? Link to comment Share on other sites More sharing options...
Chopsaw Posted December 19, 2017 Share Posted December 19, 2017 You can make custom Muntins. https://www.chiefarchitect.com/support/article/KB-00930/creating-custom-muntins.html Link to comment Share on other sites More sharing options...
ChiefWorkhorse Posted December 19, 2017 Share Posted December 19, 2017 Thanks chopsaw. However, I have no idea where the load muntins tool is. I typed in search box and nothing came up. Also, drawing lines on glass is good for elevations, but doesn't show up on perspective camera views. Guessing that's why one must "Load Muntins". Link to comment Share on other sites More sharing options...
Chopsaw Posted December 19, 2017 Share Posted December 19, 2017 Yes that is a good and bad thing about the software all at the same time. The tool will appear on the bottom toolbar after cad blocking the cad lines and reselecting the window however some doors do not allow this feature. If that is the case then things get a little more complicated and you may have to use 3D Molding Polylines like in my Symbol tutorial: Link to comment Share on other sites More sharing options...
ChiefWorkhorse Posted December 19, 2017 Share Posted December 19, 2017 It worked Chopsaw! Took me a bit, but I got it. Yes, it appears at the bottom after the block is made an then window selected. The key is to add no lites in the Open Object dialog (otherwise divides the difference in a weird way) and just draw what you want on the glass and then load muntins. A great help. Thank you. Now if they could just design it so we can add muntins at different thicknesses. And thank you too Solver! Link to comment Share on other sites More sharing options...
Chopsaw Posted December 19, 2017 Share Posted December 19, 2017 7 minutes ago, ChiefWorkhorse said: Now if they could just design it so we can add muntins at different thicknesses. There was a recent request for thickness and profile which can be done custom with the 3D Molding Polyline but is quite complicated. But if you mean width, then that can be set in the Window Plan Defaults under the Lites tab. Link to comment Share on other sites More sharing options...
ChiefWorkhorse Posted December 19, 2017 Share Posted December 19, 2017 Yes, but we only get to set one width for all. An easy variance would be cool. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 19, 2017 Share Posted December 19, 2017 One Default width that should satisfy most builds but you can also adjust it for each individual window by wiping out the (d) and entering the new width. If you need to have different widths in the same window then again 3D Molding Poly lines or symbols. Link to comment Share on other sites More sharing options...
