GTdraftingdesign Posted August 25, 2017 Share Posted August 25, 2017 Hi, Can someone please explain to me how to correct a wall material overhang issue? Please see .jpg. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 25, 2017 Share Posted August 25, 2017 Not exactly sure what you did without the plan file but you could take a look at the default bottom height for the wall. Link to comment Share on other sites More sharing options...
GTdraftingdesign Posted August 25, 2017 Author Share Posted August 25, 2017 Everything was going fine until I changed the room floor to floor supplied by the foundation room below. The image i uploaded looks correct to me. I'm not sure where to find bottom height of walls at. I'm still learning Chief. Link to comment Share on other sites More sharing options...
rlackore Posted August 25, 2017 Share Posted August 25, 2017 You can find the setting Chopsaw is referring to by selecting the wall and opening the Wall Specification dialog box and looking under the Structure tab: Link to comment Share on other sites More sharing options...
GTdraftingdesign Posted August 25, 2017 Author Share Posted August 25, 2017 My wall looks like yours. The material is falling even lower than the footing. I'm pretty confused. Kile_Office-GT06058-082317.plan Link to comment Share on other sites More sharing options...
Chopsaw Posted August 25, 2017 Share Posted August 25, 2017 Open your wall definition and set brick ledge depth back to 0" and it looks much better. Link to comment Share on other sites More sharing options...
GTdraftingdesign Posted August 25, 2017 Author Share Posted August 25, 2017 Now that is just crazy that brick ledge depth would change like that. Thank you for looking into it. Link to comment Share on other sites More sharing options...
Kbird1 Posted August 26, 2017 Share Posted August 26, 2017 It's not one I have seen before ...bit strange... but I haven't seen a 37" brick ledge before either.... that front wall could be made a Pony wall with the bottom 36" as a copy of the Main wall definition with the rusted metal set as the outer layer ....that way you don't need to use Base cabinets for that....and it's basically all done Auto. you could of used a Wall Material Region in X9 too or the old standby of a Soffit from the Cabinet Menu with the rusted material applied. In the wall definition I also noticed you are dimensioning to framing ...is that normal where you are? allowable ? cos it could make a Building too big , like a back yard Office or shed maybe allowed for eg 12'x12' add plywood or osb and you are an inch over requirements... something to check in your area perhaps, and ply wood is normally Flush to the Foundation line. M. 1 Link to comment Share on other sites More sharing options...
