EGBPro Posted August 3, 2017 Share Posted August 3, 2017 I cannot get this shelf ceiling to behave. I have tried everything I can think of. The bathroom itself is vaulted. There is a water closet that also has a shelf ceiling but that one is perfect. I tried to match every parameter of that room to this one but nothing works. I have two ceilings to make things worse!!! ALso that horizontal band between the lower and upper walls just appeared as well!!! HELP ME PLEASE!!! Thanks. Link to comment Share on other sites More sharing options...
glennw Posted August 3, 2017 Share Posted August 3, 2017 You must have forgotten to post the plan. Link to comment Share on other sites More sharing options...
jcaffee Posted August 3, 2017 Share Posted August 3, 2017 1 hour ago, glennw said: You must have forgotten to post the plan. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted August 3, 2017 Share Posted August 3, 2017 I assume that you are trying to create a standard flat ceiling in the bathroom versus the vault. If framing is not an issue then consider just using a 1/2" thick polysolid shaped to match the wall layout and suspend it to the desired height. Link to comment Share on other sites More sharing options...
EGBPro Posted August 3, 2017 Author Share Posted August 3, 2017 Sorry about that. Very funny lol Barrier Residence 3.zip Link to comment Share on other sites More sharing options...
