Base Casing Plinth Blocks
brushpark
The home I am working on has many cased opening with plinth blocks not to mention all the doors.  Is there a way to stop the baseboard from turning the corner and overlaying the casing and adding a plinth block without doing this manually?  See the attached sketch.
I haven't placed the plinth block yet.  The picture shows the baseboard not stopping at the casing, turning 90deg and overlaying.  I would like the base to stop at the casing automatically so I don't have to create a room molding polyline and remove the molding on the line edge.  I have the plinth block option toggled, but noticed it doesn't display in the camera view.
Look in the hallway where the revision balloon is.  My fix was to create a plinth block and make it thick enough to cover the base molding.  If you delete the plinth block, it should become clear what my issue is.  The openings are cased leading down the hallway with plinth blocks.  Not only does the plinth not show, but the base board heads down the hallway and turns 90 deg onto the cased opening where the plinth is.   I would have to create a molding polyline and remove the molding from the polyline edge.  It's more work and if the wall moves, I have to manually change the molding polyline.
blume floor plan.zip
Chief does not create 3D plinth blocks automatically and you have to manually place them if you want them to show up in camera views.
As for the base molding not bumping into the door casing or plinth block, the easiest way to handle this is to convert the hallway base molding into a manual molding polyline using the "make room molding polyline" tool.  Then just edit out the edges you don't want.
